Results 1 to 11 of 11
Like Tree4Likes
  • 3 Post By uiv
  • 1 Post By sherwan_88
Thread: Help regards rims from 4x4 guys
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    Default Help regards rims from 4x4 guys
    Hi, its my first thread in 4x4 area, well i need a lil help regarding steel rims, i have seen you guys mostly use custom steel rims with custom dishes according to your need specially on MOGS, can someone let me right direction in such matter, wana make custom steels for 4x100 pcd thanks
    FKP
    FKP is offline
    FKP's Avatar
    Mar 2006
    1,068
    62 Post(s)
    honda tech wle shashkay (Y)
    uiv
    uiv is offline
    uiv's Avatar
    Jan 2006
    1,683
    67 Post(s)
    Step 1: Acquire 4,5 steel rims.
    Step 2: Go to the truck workshop road (Fort Road?) perpendicular to Badami bagh market.
    Step 3: Ask around for rims fabricators, select one.
    Step 4: Get your custom rims after a couple of days and take 'em to a chrome shop (I'll help on it later).
    Step 5: Profit!
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    Quote Originally Posted by uiv View Post
    Step 5: Profit!
    Roger that
    Sent from my HTC One X using Tapatalk 2
    thetigerzzz's Avatar
    Jan 2013
    37
    1,160
    31 Post(s)
    Road Called Kilay wali gahati
    sherwan_88's Avatar
    Apr 2009
    Sialkot
    28
    894
    32 Post(s)
    Welded rims made locally are always a bad idea. Just saying.
    qwertypoiu's Avatar
    Feb 2007
    29,132
    153 Post(s)
    3 Thread(s)
    Quote Originally Posted by sherwan_88 View Post
    Totally agreed, I would further add use the Stock Oem rims its pretty good for normal/bit bigger tires and anything bigger then that would first need suspension lift and thats different level. Best guidance one can give you is knowing which vehicle you are going to put it on.
    RIP
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    [QUOTE=qwertypoiu;4564372]Totally agreed, I would further add use the Stock Oem rims its pretty good for normal/bit bigger tires and anything bigger then that would first need suspension lift and thats different level. Best guidance one can give you is knowing which vehicle you are going to put it on.[/QUOTE
    thanks for looking into it, well i actually want in to use in sedan, not daily driven wheels but you can more say show car wheels. m adding an image for ref, i want it do be on 15"x4x100 wheel size, all i need is correct offset figures, above mentioned about market can get me dishes, weld, but i have to assist them about it, have a look!
    shazo's Avatar
    Aug 2010
    26
    3,418
    240 Post(s)
    7 Thread(s)
    or this one, also known as jdm steel rims
    Badpigs's Avatar
    May 2009
    26
    2,435
    55 Post(s)
    5 Thread(s)
    laley these have incremental dia from the base till the lip to give them a 3 piece look , u can check out the ref pics , for instance if u add custom lips to 15'' they would end up with a total dia of 16'' or 16.5'' , that means you will need welds at both ends of the wheel and if they end up anywhere between integer figures then its gonna be useless as finding tyres for such sizes is not feasible and u cant mount/stretch a 16'' tyre on a 16.5'' wheels , just an example
    LIVE 4 NOTHING .........................BUT DIE 4 SOMETHING
    waqqasnasir's Avatar
    May 2010
    31
    1,106
    18
    10 Post(s)
    2 Thread(s)
    is it worth ???
    Winning is not every thing .... its the only thing
