Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By paend
  • 1 Post By meh1
Thread: suzuki potohar
    paend's Avatar
    Mar 2013
    35
    Default suzuki potohar
    aoa dear friends...
    I have suzuki potohar 2001 CNG,petrol ...now a days my jeep engine is consuming oil almost 1 L after 1000 km's in long journey...I am using Havoline formula 20w-50.
    also I would like to mention that its starting is fine ...it gives no smoke either blue or black...
    does it mean engine is going weak...or some head gas kit or other seals may be leak...plz suggest....
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    Quote Originally Posted by paend View Post
    aoa dear friends...
    get compression test done. seems like it needs a head job.
    paend's Avatar
    Mar 2013
    35
    Thanks dear u mean head head gas kit...???
    ZainMahdi's Avatar
    Dec 2012
    22
    928
    50 Post(s)
    ^^nope. He mains that the head of the engine, which includes piston rings, has to be rebuilt. My Cultus has the same issue; mechanic gave an estimate of Rs 20k-25k.
    paend's Avatar
    Mar 2013
    35
    dear mehdi shb ! friend of mine told me to replace pvc valve as last attempt....if problem occurs even after that ...then I will have to replace rings.piston etc
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    bro by head job i mean valve work. if diagnosed and suggested by mechanic.
    meh1's Avatar
    Feb 2012
    Sahiwal
    1,361
    90 Post(s)
    compression test will tell you if rings and pistons work is required
    paend's Avatar
    Mar 2013
    35
    ok dear presently I m in quetta .n asked people ..I think this test machine is not available in quetta...can some one tell me whether this is available in multan...I think it should be there...
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    even a bad pcv can't cause an engine to burn that much oil, the engine definitely needs an overhaul
    haters gonna hate, potatoes gonna potate
    paend's Avatar
    Mar 2013
    35
    dear bro ! plz tell me only replacing rings is the solution or I will have to go complete overhauling ....also how much both of these cost for suzuki potohar 1000 cc engine....????
