Results 1 to 20 of 20
Like Tree2Likes
  • 1 Post By gallian007
Thread: Suggestion regarding Purchase and Restoration of 60 Series LC
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    Default Suggestion regarding Purchase and Restoration of 60 Series LC
    Aslam-o-Alaikum,
    Hope every one is doing fine. I dont have much experience owning a 4WD....had a 2001 Hilux (3RZ-FE) and 2004 Hilux (5VZ-FE) face-lift model in Australia......loved both.....but never had much experience in maintaining them as I kept both for a few months....thus I need some help from the experts here regarding possibility of purchase and restoration of a 60 series LC
    Vehicle in question belongs to one of my friend has one......he says its 1985 model and has those square lights in the front.....has a 2400 CC diesel engine...guess its a 2L as he took it out of his 1991 Prado.....engine has a lot of oil leaks and needs replacement.....also have heard this engine has the problem of head cracks
    As far as the body is concerned.....its needs a new paint as its white color is all faded.....has a bit of rust on the ends where the wheel arch meets the base......nothing major though.....did not take any pics but guess it wont be that expensive
    So my question is
    1- How much should be the fair price of this jeep considering it needs a new engine, new paint job, fixing the rust bits and new tyres
    2- What engine would best suit this jeep, I want to use it occasionally as a daily driver plus soft off-roading
    Views would be highly appreciated and would definitely help me decide
    we ride together......we die together.......BAD BOYS 4 LIFE!!!!!!!
    cherokee's Avatar
    Nov 2006
    49
    52
    I came across 1988 60 series which was govt auctioned with original B3 engine. It needed paint only and maybe Lil title bits. The demand was 300,000. Now you can make your own calculations.
    qwertypoiu's Avatar
    Feb 2007
    29,144
    153 Post(s)
    3 Thread(s)
    Dont pay more then 300k for this vehicle And I guess 200k will be a good deal.
    New engine should be a 1hz or atleast a 2h and end of the day if you want to make it perfect it should cost you 7 to 8 lacs.
    RIP
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1020 Post(s)
    19 Thread(s)
    5
    6
    if it is already registered fair enough otherwise a six figure adjustable withholding tax is applicable
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    yup....it is already registered....guess its Islamabad and all token are up to date......I have already offered him 2 lakh considering the amount of work required.....he has to get back to me as his father is going to make the final decision
    1h or 2h sounds fine.....what if I want to go for a petrol....5VZ-FE.......or if I want to slam a 2JZ-GE or 1UZ-FE
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    Quote Originally Posted by cherokee View Post
    brother did u buy it??????.....if not, may I know the location its at or the contact detail???
    cherokee's Avatar
    Nov 2006
    49
    52
    @umarsaryar my friend knows the location you can call him for directions on 03005271101
    gallian007's Avatar
    Feb 2008
    25
    59
    Dont even think of putting a 2 jz-ge.I have had a very bad experience. Now doubt 2jz is a very good engine but its just not a Jeep engine. Mating it with the your original transmission is the biggest problem. Even the best mechanics are unable to synchronize it perfectly. 1uz-vvti is a better option. If budget is not an issue then forget about these engines. Go for a B-3, 13BT, 3-F or a 1-HZ(best option in my opinion) depending on your likes and usage or requirements.
    But all these engines are expensive these days and you can forget about mileage (except b3/13 if tuned properly)
    and if you REALLY want to jump in it, then go for the MIGHTY 12-HT!!! One of the best diesel engines ever made and the best suitable engine for a 60! but it will thrash your pocket
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    thanks brother....can u please tell me your friend's name or your name....dont want to shock him when i call
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    Quote Originally Posted by gallian007 View Post
    bro the only reason I mentioned 2JZ was that I have seen a few Prado's available with this engine and have seen a LC60 in member ride section having a 2JZ-GTE.....so what about a 1KZ??????....any comments on that???
    just want to keep the budget within limits.....dont want to spend north of 3 lakhs on the engine
    gallian007's Avatar
    Feb 2008
    25
    59
    2jz-ge and 2jz-gte are pole apart engines. and that ride you are mentioning is built for rally.(sam's)
    1Kz is a good engine but for a prado not for a 60. you can get the engines I mentioned in 3 lac rupees if you survey properly.
    Also I would advise to spend as much on the mechanics of the rig as possible. theres is no need to repaint the whole jeep. Just get rid of the rusty parts. I would again say go for a 13B or 1HZ. (even better)
  12. #12
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    I have the same plan to fix the jeep up mechanically and fix the rusty bits.....dont mind driving a faded jeep as long as its good mechanically and interior wise
    U know of any good jeep mechanics in lahore who wud fix it up properly.....never kept a jeep in Pakistan so dont know about any mechanics
    So 13B or 1 HZ......any idea about their price???
    Also please share your views about 1UZ???? Which one to go for vvti or normal?????.....had a Soarer with non vvti 1UZ in Australia so not sure about mating it with the 60 gear box.....have seen few FJ's with this engine
  13. #13
    gallian007's Avatar
    Feb 2008
    25
    59
    As for mechanics in lahore, you should seek help from any of the mean machines member (4x4 club in lahore, check on pakwheels) they will guide you better
    I would suggest to go for a vvti one. but when I was putting engine in my 60, gurus advised me to go for a normal one to keep it as simple as possible (goes with 60)
    I will ask around for the prices of 13B and 1Hz
  14. #14
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    Thanls brother for your insight
    So did u end up putting a 1UZ in your 60 or did u go with some other engine?????
    Will send a message to one of the mean machine members regarding mechanics.......thanks again
  15. #15
    gallian007's Avatar
    Feb 2008
    25
    59
    I ended up buying another 60 with a 12HT, 88 model! ;-) The other one still runs on 2jz
  16. #16
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    how much did u buy the one with 12HT???????........just for the price idea
    and how the one with 2JZ is performing????........I know I know u have told me to stay away from it but want to know why your experience is bad with 2JZ????
  17. #17
    gallian007's Avatar
    Feb 2008
    25
    59
    Bought it for 8 lac. Biggest problem I had was coupling with the original transmission which is H55 (5 forward manual). You have to make a custom adapter plate to connect the engine and the gear box (with clutch and fly wheel of course) Aligning this adapter plate perfectly is the biggest issue which leads to very irritating jerks when you change gears. I am unaware of the deep technicalities behind these things but I am telling you what I know and what I understand. Also the heavy differentials of the 60 just doesn't go well with the high rpm 2jz. So you might have to change the differentials as well. Mating the engine with its original transmission (w57 or w58 i guess) might solve this but I am not sure how would it effect the power and torque to drag such a heavy vehicle.
    Secondly, low end torque of 2jz is very low as compared to the diesel engines I mentioned because it is designed for a car (weight factor) So you will have to drive the jeep on high rpms if you really want something out of it especially on mountains when driving on 2 wheels. And lastly originality is the name of the game. Sticking to the engines which originally came in the 60 will save you lots of trouble.
    Having said that, 2jz is a fantastic engine but its just not a Jeep engine. I have smoked multi valve cruisings (80 series) and other jeeps both on plane and mountains. Very low maintenance/ no heating issues or other hastles which one do face in older diesel engines.
  18. #18
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    many thanks brother for your comprehensive reply
    I totally agree that 2JZ is best suited for cars.....had a couple of Supra's in Australia with the same engine and the car really flies with this engine......only asked about it as have seen a few FJ's and Prado's with this engine so just thought of it as an option....as I have no experience at all regarding jeep restoration and maintenance, so wanted to get an opinion from someone who has experience in doing so.....yes mating with the original gear box would be an issue and I guess its best suited to throw in a diesel engine to make one's life easy
    now the last part of your comments where u mentioned smoking 80 series.....was it with the 2JZ or some other engine?????
  19. #19
    gallian007's Avatar
    Feb 2008
    25
    59
    yes with 2 jz with some mods on intake and sequential fuel pumps
  20. #20
    umarsaryar's Avatar
    Aug 2006
    36
    213
    5 Post(s)
    Thanks bro....lets see how the deal goes with my friend
