Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Any Rocky expert out there
    junaidaftab86's Avatar
    May 2008
    30
    31
    Default Any Rocky expert out there
    I am parting ways with my Suzuki SJ410, and looking ofr something powerful and big.
    I have my eyes set on a Daihatsu rocky 1986 model, which was recently auctioned from Army, the engine, gear 4wd is in good condition. I want to query the following things.
    1) Engine is non-turbo. I am not sure if the turbo was removed or it is originally without turbo, any signs?
    2) What is approximate mileage for such vehicles in long journeys?
    3) Any electronic power steering fitting possible? If not i will go with hydraulic power steering.
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Quote Originally Posted by junaidaftab86 View Post
    Please com up with exact details. You are asking about the engine and mileage and not mentioning whether it's diesel or petrol? It's cc? Gear 5 fwd or 4 speed? Tyre size? etc etc??????????
    May 2008
    30
    31
    Forgot to add, it's normally aspirated 2.8L diesel original daihatsu engine, 4 speed and tire dia is 28"
    Sent from my iPhone using Tapatalk
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Go for a mechanical power steering. The electrical ones normally do not work good in 4X4's while off roading. And in my opinion a 2.8 non turbo with this weight and tire size should give not less than 10 or 11 on highways if driven below 100km/ hr.
    May 2008
    30
    31
    Any availability and approx price of 5 speed gearbox
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    Electronic Power Steering on a Rocky 1986?!
    Hats off to the imagination though!
    On a side note surprisingly kabli Rocky parts are hard to find nowadays and don't come cheap. Nevertheless, 5 speed boxes, power steering and all other stock gizmos should be findable in Peshawar / Rawalpindi.
    "If YOU don't believe in what you're doing it'll never work."
    May 2008
    30
    31
    I have installed eps in Potohar, its working superbly. My preference for EPS is because its less messy, and if i get desired size motor out of any kabli vehicle, with little machining it can be installed.
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    Dont go for 5 speed gear box... it will drop ur milage dramatically... still if u want to go for 5 forward gear then also change the engine to 2L turbo..
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    This belong to me..
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    If u need a new kit for break calipers for rocky.. then i can help... difff ratio.. engine info .. hopefully i can help..
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    The parts availability of Rocky is not good .
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
  12. #12
    May 2008
    30
    31
    Any reason for that? I was of the impression that as all Cj-5 cj-7 conversions were using rocky, the part supply must have been good
  13. #13
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    Only gear n differentials of rocky r used ... not all the parts..
  14. #14
    May 2008
    30
    31
    Any parts that i should be concerned with, that rocky has habit of replacement?
  15. #15
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    Like what..
  16. #16
    May 2008
    30
    31
    The parts that are required mostly like, engine parts, suspension parts, body parts
  17. #17
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    All r available.. local.. Chinese .. so called Japanese.. engine parts.. suspension .. but body parts available r not new..
  18. #18
    May 2008
    30
    31
    Thanks.. And what is the price compared to kabli toyota parts.
  19. #19
    tataries's Avatar
    Feb 2010
    Gujranwala
    34
    16
    Like which part...
  20. #20
    May 2008
    30
    31
    Engine parts.. Suspenaion parts like bushes, brakes etc
