Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
Like Tree1Likes
Thread: Pajero specialist required in karachi.
    patroler's Avatar
    Feb 2011
    101
    3 Post(s)
    Default Pajero specialist required in karachi.
    Dear all, i am facing some engine problem in my 1990 pajero, (4d56). The engine is weak, consuming oil, underpower, and giving poor milage. I wish to get it overhauled, but i need some realy good mechanic for this job, as i dont trust unknown mechanics who only do experiments on it.
    Experts suggestion and help is highly and urgently needed in this regard.
  2. #21
    mohd-ammar's Avatar
    Mar 2014
    27
    I recently got my 4D56 engine overhauled, it was apparently blown. The sound is same as it was before overhauling (when it was in good condition, sound improves as engine running progresses). There is no issue at all in overhauling a 4d56 engine. The cost purely depends on the number of things you need to repair/ replace. Mine took around 1 lac but it also includes new radiator worth Rs. 8500 and a clutch/ pressure plate worth Rs. 9300 and brakes worth Rs.4100 and a new Head worth Rs24,000. I don't believe in engine swapping not at least with the same one until your engine has completely exploded (which I believe is not the case). If you know of a good mechanic and a good parts dealer (which normally people neglect, they depend on mechanic for parts) then engine overhaul is the best option. You know what you are putting in and what exactly is the condition of each and ever bolt. Visited shershah personally for a replacement head just 2 weeks back, trust me all the apparently shiny engine that they claim to be as good as new are not reliable at all. Checked four 4D56 engines for head, and they had minor cracks some where or the other. Hence, decided to replace the head with new one!
  3. #22
    patroler's Avatar
    Feb 2011
    101
    3 Post(s)
    thanks ammar, i got ur number, i will be contacting u soon for further help and ur advice.
