Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Like Tree14Likes
Thread: Suzuki Sj410 (LWB) Engine
    Amar85's Avatar
    Aug 2011
    40
    Default Suzuki Sj410 (LWB) Engine
    Suzuki Sj410 LWB Engine -1508525
    Hello Pakwheelers!
    I have planned to upgrade my Suzuki Sj410 engine. The current setup is Margalla's engine with 5fwd Suzuki sierra gear, but the engine is too weak now and not giving the power i need. So both Petrol and Diesel engines are under consideration for conversion. The engine i am looking for should be powerfull as well as fuel efficient. Eagerly waiting for your comments and suggestions.Thank you. @Noman8ff: Sir plz share ur experiences in this regard.
    Alcohol and calculus don't mix. Never drink and derive..
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Salam brother. the stock engine for this veh was mostly 1000cc and u r running a 1300cc which is weak. So the best option would be to go for the same 1300 kabli engine. Preferably the carborated one, unless your last engine was EFI and has the EFI wiring properly working. Diesel engine should be the last priority and that to only a 1N. 1C and 2C are powerful and fuel efficient but are very heavy for this veh so in a way you'll loose the grip and balance of yr veh. So the only choice is of 1C.
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Amar85 View Post
    Hello Pakwheelers!
    g13a will be bolt to bolt swap on it as the vehical is running on margalla engine it will be powerfull as well as economical
    Amar85's Avatar
    Aug 2011
    40
    Quote Originally Posted by noman8ff View Post
    thanx Noman bhai for the prompt reply.
    should i install Sierra 1300cc engine in it?
    Wot about its fuel efficiency?
    any price idea for the both the engine and gear?
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Brother the tendency in our mechanics is that as they see the engine, they tell u that u r running a margalla engine. Basically japan have fixed this engine in both jimny, sierra, samurai, margalla and surely in many other cars around. So actually u were previously also running the jimny engine in yr sj 410 with it's original 5 fwd gear. The difference is that in margalla it's fixed side ways and in jimny they are fixed from front to rear.
    Just change the engine g13 and make life easy for u. The fuel efficiency will be around 10km/ ltr on long. And the price of kabli 5 fwd gear will be around 30k. no exact idea about the engine, surely 1 lac plus.
    Were u initially using an EFI or simple engine?
    Amar85's Avatar
    Aug 2011
    40
    Thanx again for icreasing my info about g13 engines.
    The engine currently installed is non efi one.
    its decreasing oil but gives around 10km/ltr on long running but felt it weak while off-roading.
    The jeep also doesn't go beyond 80km/hr on highway.
    I am using 16" non directional tyres (general)
    Which is the best tyre size/profile for this jeep on road and sand.
    * tyres in pic are earlier
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Yes, 16" tyre size is the best having the best of diameter for a 100cc and 1300cc engines. I will suggest not to go for an EFI engine. You know the reason as our electricians have limitations, and than it will take you 6 months to fully get over all electrical issues. A CDI distributor is going to work better. Either get it overhauled or go for a kabli 1300cc.
    For the limited top speed, can u pls let me know the following
    1. What diffs are you running? The stock sj 413 mostly had the 9:37.
    2. Do you have alloys or steel rims?
    3. Do you have an RPM in yr car? And what's the readings when you are on 80km/ hr?
    Awais_jan's Avatar
    Oct 2010
    Mansehra
    25
    1,858
    33 Post(s)
    Why not you go for M13a , jimny engine , my jimny give atleast 14km/ltr and power is very good
    Sent from my LG-F340K using PW Forums mobile app
    Engineer + Car Enthusiast = Awais Jan
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by Awais_jan View Post
    I was about to give him same advice as m13a is cheap 40k with complete uncut wiring but pp consider it a flop engine that why I didn't adviced him m13a
    Awais_jan's Avatar
    Oct 2010
    Mansehra
    25
    1,858
    33 Post(s)
    Quote Originally Posted by saboor73 View Post
    Is it really flop engine???
    Can you find me a good complete engine in 40k I am willing to buy
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    no bro it a very good engine if your were in karachi I would have found you one in good condition
  12. #12
    Amar85's Avatar
    Aug 2011
    40
    @noman8ff
    1. Noman bhai it has stock diffs, dont know about the ratio thing(plz put some light on it)
    2. I have installed 16" steel rims with General non directional tyres.
    3. In 4th gear on 5000rpm it goes upto 90km/hr and as i shift to 5th gear, it comes down to 80km/hr on 35000rmp.
  13. #13
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    A big LoL :p
    i dont how n who told you guys that these engines are costly...they r cheap....
    bro i suggest u to Go for G15 sohc distributor.... u can find it in 55k with wiring and easily fixed with the jimny's 1.3 gear 5 speed. dohc engines are of high compression and they got coil issues while when they get more heatup n makes the coil to get melt n thn missing problem and a coil set cost u 10k lol....
    a distributor engines become more powerfull when they get more heatup..... G15 is around 103 hp ....m15 ignis sports also a good option got 109 hp v powerfull engine....but the same prob goes up....coil issues lol ....sooo i suggest u to change the hissaas of jeep to 1300cc jimny sierra orginal hissas in order to work properly otgerwise if u r running on 1000cc hisaas thn no point to go for g15 or m13 or g13 cuz it will not give u top speed to max.
    0302-4469003
  14. 01-12-2014, 12:48 AM
    PakWheeler
  15. #14
    Amar85's Avatar
    Aug 2011
    40
    @noman8ff
    Salam Noman Bhai,
    waiting for ur guidance.
  16. #15
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by kenblock3 View Post
    A big LoL :p
    0302-4469003
    I think your are just idiot all info you share is wrong I DOHC m series engine have coil problem but it can be over come by using irridium plugs I have seen a guy have use m13a engine in his liana for 200,000 + km and it was still strong he just changed it becoz he need more power he swapped it with m18a which costs 75k with complete engine un cut wiring and how told you g series engine doen't have coil issue I have seen many baleno with city coil as baleno coil are hell expensive
  17. #16
    Awais_jan's Avatar
    Oct 2010
    Mansehra
    25
    1,858
    33 Post(s)
    My jimny m13a have 112000 km on odo , and engine is perfect and never have coils problem , I am using irridium plugs
  18. #17
    qwertypoiu's Avatar
    Feb 2007
    29,141
    153 Post(s)
    3 Thread(s)
    If i am not wrong then swift m13a and jimny ones are a bit different, secondly the rwd gear of sj410 does not directly mate to m13. for perfect mating jimny gear is needed which costs 1lac or 2 if i recall correctly
    RIP
  19. #18
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    @noman8ff
    Salam brother. If yr veh model is 85/ 86/ 87 it must be with a 9:37 diff with which the rpm should not be 5000 on 90km/ hr. It looks either the model is older or u are running the older model diffs. may be 8:37 which is very low resulting in more rpm.
    Secondly do check the electrical issues and the current (distributor) timings settings and the 1300 should at least run till 120/ 130 km hr.
    Tyre size is perfect.
  20. #19
    Amar85's Avatar
    Aug 2011
    40
    Noman bhai i rechecked diffs, they r 9:37.
    Two months ago i blown gasket while offroading then replaced it.
    Before that vehicle was running fine and was going upto 120 to 130km/hr.
    Tyres then i was using were 175/80 R15 (stock rims)
    But as the G13a engine replacement is finalized, plz help me on follwing quries:
    . Should i change diffs also to get proper power and milage?
    . I need wider tyres. Which size/profile will suite best both on road and offroad.( specially on sand)?
    . How to upgrade its suspension?
    Thank you
  21. #20
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    Default salaam
    Bro first of all you have to use the sierra elk model gear box to fit accurate with g13a engine othrwise it can b fit also with the previous model of sierra but it will disturb u in top speed ... after 4th gear..
    and whats your pocket for suspension??? tell me u want best of best or best in cheap price ??? ill guide u thn.
    just tell me u using leaf spring suspension or shocks absorber???
Tags for this Thread
