Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Like Tree14Likes
Thread: Suzuki Sj410 (LWB) Engine
    Amar85's Avatar
    Aug 2011
    40
    Default Suzuki Sj410 (LWB) Engine
    Suzuki Sj410 LWB Engine -1508525
    Hello Pakwheelers!
    I have planned to upgrade my Suzuki Sj410 engine. The current setup is Margalla's engine with 5fwd Suzuki sierra gear, but the engine is too weak now and not giving the power i need. So both Petrol and Diesel engines are under consideration for conversion. The engine i am looking for should be powerfull as well as fuel efficient. Eagerly waiting for your comments and suggestions.Thank you. @Noman8ff: Sir plz share ur experiences in this regard.
    Alcohol and calculus don't mix. Never drink and derive..
  2. #21
    Amar85's Avatar
    Aug 2011
    40
    @kenblock3
    W Salam,
    bro can u plz tell me wots the difference bw Sierra elk and other Sierra gearbox?
    i have stock leaf spring suspension and want to make it little bit smoother.
  3. #22
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    Quote Originally Posted by Amar85 View Post
    Noman bhai i rechecked diffs, they r 9:37.
    Two months ago i blown gasket while offroading then replaced it.
    Before that vehicle was running fine and was going upto 120 to 130km/hr.
    Tyres then i was using were 175/80 R15 (stock rims)
    But as the G13a engine replacement is finalized, plz help me on follwing quries:
    . Should i change diffs also to get proper power and milage?
    . I need wider tyres. Which size/profile will suite best both on road and offroad.( specially on sand)?
    . How to upgrade its suspension?
    Thank you
    If your engine is loosing power, than going to high speed diffs will further decreases the top speed. High speed diffs can only be used if only the rpm increases and the vehicle has the power to further accelerate.
  4. #23
    noman8ff's Avatar
    Oct 2007
    41
    1,759
    10
    72 Post(s)
    And first get over with the power issue than we'll discuss the lifting and wider tyres.
  5. #24
    Amar85's Avatar
    Aug 2011
    40
    Thanx Noman Bhai.
    From where can i get Sierra engine and gearbox from karachi and for which model i should go for?
  6. #25
    ag3ntx's Avatar
    Jun 2009
    32
    52
    G13BB with 5 speed manual transmission in my Potohar.
    Sierra differential, transfer case, leaf springs, drive shafts.
    205 70 R15 tyres
    Top speed on highway 120 km/hr
    Fuel consumption 11 to 12 km/l on highway
  7. #26
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    Bro iv recently done an experiment wid the my sj410 n its a best now aftr spending n waisting alot of money...
    for better power and 165 km/h top with the G13A engine u need to go with 45 numb hisaas + tubes(tubes are only for make tires outside n wider).
    if 45 not avaible search for 43.
    and use the sierra 4wheel gear cuz its garrari 1 and others 1000 cc n 660cc 4wheel gear got chain istead of garrari anf in max torque possibility of breake the chain.
    G15A is a best option and it will gv u 15 14 km average....power to wieght ratio makes it economical. its easily equipped with the sierra 5 speed gear n 4 wheel. muuuah
  8. #27
    waqqasnasir's Avatar
    May 2010
    31
    1,106
    18
    10 Post(s)
    2 Thread(s)
    Quote Originally Posted by kenblock3 View Post
    nice information
    Winning is not every thing .... its the only thing
  9. #28
    sherkhan's Avatar
    May 2007
    49
    60
    2 Post(s)
    Quote Originally Posted by ag3ntx View Post
    205 70 R15 tyres
    Best configuration MOD IMO and a very neat vehicle MashAllah.
  10. #29
    ag3ntx's Avatar
    Jun 2009
    32
    52
    Thanks sherkhan
Tags for this Thread
