Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By saadwm38
Thread: 4x4 not working
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    Default 4x4 not working
    I have a pajero 1986, the problem is.. when i engage 4 x4 a rattle sound comes from the front differential, and it doesnt work.
    what could be the issue .. and the solution pls .
    noman8ff's Avatar
    Oct 2007
    41
    1,757
    10
    72 Post(s)
    Check the front diff than.
    saboor73's Avatar
    Oct 2013
    10,544
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    its sounds rattling or cracking
    babarhyd's Avatar
    Jul 2005
    Hyderabad
    30
    1,956
    94 Post(s)
    4 Thread(s)
    Auto hub locks or manual? Front axel broken? Front shaft bent?
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    Shaft is fine, axel is set, it has manual hub locks. .. It runs fine on 2x4. when i engage 4 x 4 the sound of some chain dragging comes from front left side.
    noman8ff's Avatar
    Oct 2007
    41
    1,757
    10
    72 Post(s)
    does the front shaft moves when u get in 4X4?
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    Yes it moves and it is quite loose from the front diff end.
    saadwm38's Avatar
    Jul 2013
    28
    40
    3 Post(s)
    The front pinion bearing might be worn out. Get under the vehicle and rattle/shake the front drive shaft near the point it connects to the front diff and notice any movements.
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    yes its quite loose from the front end where it connects with the diff.
    Demonoid's Avatar
    Jan 2012
    2,030
    6
    85 Post(s)
    2 Thread(s)
    Get your Axles check....
    https://www.facebook.com/CAR.Fest.Pak
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    **bump**
  12. #12
    saadwm38's Avatar
    Jul 2013
    28
    40
    3 Post(s)
    You need to replace the pinion yoke bearing. Another sure shot way of diagnosing the problem is take off the front diff cover (drain the oil first) and then have someone rattle the front drive shaft. And you can then physically observe the bearing if it has play in it or not.
  13. #13
    farhannk's Avatar
    Jun 2006
    44
    760
    7 Post(s)
    Thanks saad, will surely chk this way....
