Results 1 to 8 of 8
Thread: mini pajero 96 model
    altolef's Avatar
    Sep 2013
    Default mini pajero 96 model
    Hello guys,
    I have mini pajero 96 model manual on petrol I am facing problems of white smoke from my silencer since past few months and today of got worst and is giving a lot of continuous white smoke the engine temperature needle is normal can anyone please help me urgently on this. Acceleration is good pick up is good
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    If smoke has a pungent smell then its a clear indication of worn piston ring and it could be because of using contaminated fuel,get it checked.
    Never loose hope in life,every step gives u something.
    abzia's Avatar
    Oct 2006
    32
    337
    10 Post(s)
    It could be due to injector or their actuation, especially if you've got CNG emulator installed. Usually the installation is not very good and due to poor wiring, injectors flood and hence white smoke.
    syedmughees's Avatar
    Sep 2006
    31
    369
    4 Post(s)
    Do you have turbo model? if yes than there may be chance of turbo ring got brushed. By-pass turbo and i hope issue will be solved.
    Love your Machine it reflects your personality
    altolef's Avatar
    Sep 2013
    Syedmughees yes turbo ring has been brushed should I consider replacing the turbo or should I by pass it?
    altolef's Avatar
    Sep 2013
    How should I get it bypassed I'm in Karachi please suggest
    afnan.bashir's Avatar
    Jan 2013
    1,994
    5
    147 Post(s)
    6 Thread(s)
    If you are referencing it white smoke in winters then its normal.
    Otherwise if you have coolant in your radiator (colored stuff) and you see white smoke this means your gasket is allowing coolant to enter into combustion chamber. In that case get its compression test done
    93 Accord CB7 (Sold) / 2005 CL7
    altolef's Avatar
    Sep 2013
    Its the oil seal that is leaking can I replace the oil seal instead of replacing the whole turbo as said by the mechanic
