Results 1 to 7 of 7
Like Tree5Likes
  • 2 Post By tareen
  • 1 Post By Demonoid
  • 1 Post By hassan211
  • 1 Post By fasboo
Thread: 1kz Help !
    hassan211's Avatar
    Jul 2014
    84
    Default 1kz Help !
    Salam
    i have 97 Prado 1Kz te..and facing serious problem with its Radiator, After 50 to 60 kilometer whole water dries up
    There is no leaking from any pipe or from anywhere else
    Is anyone facing same problem What should i do ??
    Urgent help required Thanks
    ahmed2396's Avatar
    Dec 2011
    36
    2,334
    5
    55 Post(s)
    7
    Does the water in radiator have bubbles? Engine oil is clean or milky? might be warped head or gone HG
    hassan211's Avatar
    Jul 2014
    84
    Quote Originally Posted by ahmedraja1996 View Post
    Head Gas kit is changed Mobil oil is changed 2 days before but still problem not solved
    tareen's Avatar
    Feb 2005
    43
    634
    15 Post(s)
    A possible sign of minute leakage in cooling system that starts under pressure and hot components turn it to steam immediately. Pls do cjeck for fresh & bright rust stains on all components from radiator & its cap, pipes , waterbody etc.
    In such cases, sometimes it is possible to hear a hissing sound when engine is hot, water level low & engine turned off.
    *** Its a SATISFACTION thing. Only DIY guys will understand! ***
    DIYs require Space, Money, Time, Skill & Knowledge....or.......the absence of them
    Demonoid's Avatar
    Jan 2012
    2,030
    6
    85 Post(s)
    2 Thread(s)
    Get your radiator collar checked where the radiator cap is tightened, also change your radiator cap
    https://www.facebook.com/CAR.Fest.Pak
    hassan211's Avatar
    Jul 2014
    84
    Thanks all for your valuable replies...there was miner leakage in the pipe which is replaced and problem is solved now
    fasboo's Avatar
    Jan 2015
    That happened to me last week, radiator basically chokes and water doesn't pass through. Radiator needs to be serviced. Mine blew up and had to replace the top. I discovered it was completely choked. Secondly put originak Toyota coolant - works wonders.
