Results 1 to 15 of 15
Thread: The best off-roader: Bowler Wildcat
    PavementPounder's Avatar
    Feb 2005
    Dubai
    27
    3,566
    Default The best off-roader: Bowler Wildcat
    The bowler wildcat is based on the landy defender........
    N can do 0-60 mph in 4.8 secs while the astin martin DB7 does it in 4.9 secs!!!!
    Vdo:
    http://www.youtube.com/watch?v=ARcRHKosQoo
    Info:
    http://www.bowler-offroad.com/NAV1.htm
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Ah the legendary wildcat. It has appeared on TG a few time already. I've sat in a real one and trust me you'll never be ready for the kind of performance it delivers.... it's a beast!
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    Its one mean off-roader something like a Mitsu Pajero Evolution.
    Heres a lil something from the links you gave as people are a bit too lazy in opening links.
    The Frame:
    The advanced tubular spaceframe is race and computer designed, using high strength tubing in the roll cage and main braces, means the cab is both strong and extremely safe. Incorporating the damper mounts as an integral part of the frame, gives a highly rigid and stable skeletal base.
    The best off-roader Bowler Wildcat -662769
    The best off-roader Bowler Wildcat -662770
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    STYLING - The Wildcat could be described as extrovert and purposeful in its appearance,
    far more so than any of the other 4WD production vehicles available to date.
    All the curves and scoops within the body are placed for beneficial purpose.
    The entire external body of the Wildcat is G.R.P. Composite . This material has many benefits, its strong, light weight, flexible and has good anti corrosion properties.
    A minor bump on a G.R.P. panel will usually fair better than on a steel or aluminum counterpart.
    SIDE SCOOPS - Designed to draw air from the body to cool the dampers, giving optimum performance in the extreme temperature of competition.
    BONNET SCOOP - Designed to draw cold air from the wing to cool the front dampers and add extra cooling for the front mounted engine.
    SIDE VENTS - Cut into both the wings and the door these act as exit points for the excess hot air created by the dampers and more importantly the engine.
    ( If an engine is a few degrees in temperature over its optimum running temperature its BHP performance can be dramatically reduced)
    ROOF SCOOP - Available on the Wildcat Signature this has been designed to draw the updrafted air from the windscreen, the air is accelerated over the roof to internally sculpted cowling which is then forced directly onto the rear mounted radiator.
    LIGHTS - The rear lights are place high up the body for maximum visability for road or race.
    ACCESS - The Wildcat has been designed for maximum access to the engine, coolers and dampers by having the wing tops incorporated into the bonnet . The rear of the vehicle can be completely lifted to gain access to spares, dampers and fuel cell or engine depending on the model.
    The best off-roader Bowler Wildcat -662771
    The best off-roader Bowler Wildcat -662772
    The best off-roader Bowler Wildcat -662773
    The best off-roader Bowler Wildcat -662774
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    PERFORMANCE
    5.0 LITRE ROVER V8
    UNDER DEVELOPMENT - Provisional tests show incredible torque and acceleration.
    4.6 LITRE
    Delivering 218 Ps and 400 Nm of torque at 2600 rpm, the 4.6 litre unit provides effortless power throughout the rev range. Its sophisticated engine management system controls every aspect of fuelling and ignition for maximum torque, smoothness and overall performance.
    4.0 LITRE
    Producing 185Ps and 340Nm of torque at 2600 rpm, the 4.0 litre V8 is the result of engineering supremacy. For optimum power, refinement and efficiency, it also boasts the same state-of-the-art engine management system as the 4.6 litre version.
    5.0 / 4.6 / 4.0 LITRE
    All available in 4 stages of tune.
    The imformation provided is for stage 1.
    Furter imformation will be available soon.
    TD5
    This 5-cylinder 2.5 litre turbocharged diesel engine provides exceptional refinement, responsiveness and efficiency. It combines the outstanding fuel economy of a diesel with the power and smoothness normally associated with a petrol engine, and even delivers a generous amount of torque at low speeds for outstanding driveability.
    MODEL------------------------------------YEAR------0-60mph
    BOWLER WILDCAT SIGNATURE----2000--------4.8
    LAMBORGHINI DIABLO VT-----------1994------- 4.9
    SUBARU IMPREZA 2.0ltr TURBO----2000--------5.3
    ASTON MARTIN DB7 6.0ltr-----------1999--------5.2
    LOTUS ELISE------------------------------2001--------5.8
    CHEVROLET CORVETTE 5.7---------1993--------5.5
    PONTIAC FIREBIRD TRANS AM------1992--------6.3
    RANGE ROVER 4.6ltr HSE--------------1994-------10.5
    JAGUAR XK8-------------------------------1998--------6.6
    DATA BASED ON 5.0LTR UK RACE SPEC
    The best off-roader Bowler Wildcat -662775
    The best off-roader Bowler Wildcat -662776
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    INTERNAL PANELS -The internal floor, transmission tunnel and footwells are built in powder coated 16swg and 14swg aluminum. This creates a light weight, durable, protective fire wall.
    DASH BOARD - Race designed Ergonomic dash, with centrally mounted instruments, enabling both driver and navigator clear visual access. Available with incorporated fire extinguisher nozzles, directly aimed at driver and passengers legs.
    SEATS - Sports seats made from GRP and sculpted support foam for superb comfort support and safety, with harness slots to accommodate a full 6 point harness. Also available in a high-sided version for extra lateral support.
    HARNESS -Available from a four strap with snap hook fittings and press release, to an FIA , five strap, aircraft release harness with alloy adjusters.
    EXTRA FEATURES
    As well as the seats being adjustable via bolted mounts, there are two pedal sets and steering wheel options available, Enabling the perfect tailored driving position regardless of the drivers height or leg length.
    For motor sport use additional removable door appiture braces are available.
    Navigator switches for horn / wash/wipe / fan override / spot lights and any other switches you may need to allow the drive to drive are also available.
    The best off-roader Bowler Wildcat -662778
    The best off-roader Bowler Wildcat -662779
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    The one i rode in was a prototype (back then) with a 5.7L LS1 block from a Vette,... i nearly sh*t myself wehn he took a jump at around 60mp/h with 100% wheelspin!!
    beeberg's Avatar
    Mar 2006
    Select City
    33
    4,123
    great info about defender bowler wildcat., thanks for sharing it with us arid.
    life style: pakwheels
    shani606's Avatar
    Oct 2006
    43
    1,984
    3 Post(s)
    BOWLER IN ACTION
    The best off-roader Bowler Wildcat -676608
    The best off-roader Bowler Wildcat -676609
    The best off-roader Bowler Wildcat -676610
    The best off-roader Bowler Wildcat -676611
    Zeeshan Riaz Chaudhry..Hunt,eat,sleep and Repeat...
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    took my breath away....
    Shaani..you said you were converting one of your Defenders to Bowler's specs? tell me more about it please..
    Sajidd
    Pakwatan Explorer
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Shaani / Sameer,
    How about this Defender..is it better than a Bowler or is it Bowler under a different name?
    http://www.teamsaluki.com/specs.htm
    Make: Land Rover Defender 110
    Model: FIA T1 specification 110" Hard Top
    Registration No: Dubai 24780 (3)
    Year of Manufacture: 1986 (complete rebuild on new chassis - 2002)
    Total weight: 1,975 kgs
    Engine: 4.8L injected V8 (new 2004)
    Horsepower: 285 hp (34mm restrictor) 325 hp unrestricted
    Clutch: AP Racing
    Transmission: LT85 Santana gearbox / R230 transfer box
    Axles: Fully stiffened - Range Rover rear / Land Rover front
    Suspension: 8 x HT Shock Absorbers / 4 x HT HD progressive springs
    Brakes: AP Racing calipers and discs
    Fuel Cell: 300 litres purpose made by Premier / Two submersible fuel pumps
    Dash board: Full rally specification
    Differentials: Quaife limited slip diff and half shafts (front & rear)
    Bushes: Land Rover standard
    Cooling: Serck Services 4 core, large bore radiator, 2 x 13" Kenlowe heavy duty fans (suction)
    Engine Oil Cooling: Serck Services aluminium engine oil cooler
    Wheels: 16" Steel Mangels
    Tyres: 6 x Michelin XS
    Roll Cage: Tubular steel built to FIA specifications
    GPS: Garmin GPS182C
    Trip meter: 2 x Terratrip 303
    Seats: Sparco Evo 2
    Belts: Sparco 3" four point Harnesses
    Sajidd
    Pakwatan Explorer
  12. #12
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Storm, you should buy this.....
    http://www.ajeepthing.com/jeep-blog/item/57/
    Sajidd
    Pakwatan Explorer
  13. #13
    shani606's Avatar
    Oct 2006
    43
    1,984
    3 Post(s)
    ya i read this article last year in LRM magazine....its good the engine has been modified by the company "****" and its power has been enhanced.....this company enhances the power up 5.3 litre v8 with 333hp....it's really good.
  14. #14
    shani606's Avatar
    Oct 2006
    43
    1,984
    3 Post(s)
    2007 Land Rover Bowler.
    SPECS:
    DIMENSIONS
    Length - 4268mm
    Width - 2000mm
    Hight - 1816mm
    Wheelbase - 2744mm (108 inches
    ----PERFORMANCE----
    Performance -4.2ltr. Supercharged V8
    Maximum Power . DIN BHP - 450
    Maximum Torque . DIN lb.ft. - 430
    Acceleration 0-102km/h - 4.2
    Top Speed mph/ km/h - 150 / 210
    The best off-roader Bowler Wildcat -676635
    The best off-roader Bowler Wildcat -676636
    The best off-roader Bowler Wildcat -676637
    The best off-roader Bowler Wildcat -676638
  15. #15
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Found another video of the Bowler..its a must see.....
    http://youtube.com/watch?v=Z5S3G81rVYI
    Take that Evo!
    Pakwatan Explorer
  16. 15-04-2011, 08:44 PM
    Site Banned
