Results 1 to 4 of 4
Thread: cygnus engine wobbling
    saj555's Avatar
    Aug 2009
    37
    31
    Default cygnus engine wobbling
    hi, need help i own cygnus and recently came to live in rawalpindi. the jeep engine is in bad condition needs replacement of rings but couple of days back its engine wobbling i give it a little race its running f9 but even in idle its giving a little wobbling...any one who can guide me frm were to get it diagnosed or can help me finding the issue or the rt man or the wrkshp to do all th wrk........
    shadab_lodhi's Avatar
    Feb 2012
    Rawalpindi
    85
    Check the spark plugs one by one. Any one or two spark plugs may have become oil fouled. If the problem persists check the connectors and wiring at the igniters and the fuel injectors.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1018 Post(s)
    19 Thread(s)
    5
    6
    @saj555 contact respected member @msabbasi & @Vajih102 both can guide you to a reliable workshop with automotive scanner in Islamabad
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    its basic toyota troubleshooting sequence, check ignition coils for operation, mostly this is caused by one or 2 cylinders misfiring due to bad ignition coils. Do not drive the truck with misfire as it can destroy the cat converter on the misifiring bank.
    A well equipped technician can check for bad coil or even missing signal from ECU (highly unlikely but I have seen some cases like this)
