Closed Thread
Results 1 to 3 of 3
Thread: mini pajero's performance...HELP PLZZZ
    get2ali's Avatar
    Aug 2006
    34
    6
    Default mini pajero's performance...HELP PLZZZ
    SALAAMZ...
    can any 1 tell me da real price of mitsubishi mini pajero,model 96,n model 9798,n model2000
    2ndly can u plz tel me wat "TURBO INTER COOL" means.,3rdly,can u remove it n how much will dis car giv without it,n will it affects its AC?
    4THLY,CAN U PUT A CNG in it with da turbo system???n without da turbo system....
    5thly,how will it affect its AC n how is da car in general with da AC ON!!!,cuz its only 660cc.thanku!!!!!plz relply!!!!!!!!!!!!!
    MOD EDIT: This has already been discussed, plz search the Forums.
    PuNk's Avatar
    Dec 2004
    Select City
    30
    21,518
    41 Post(s)
    Already Anwsered!
    Chk ur earlier post
    http://www.haseebawan.com
    blueanwar's Avatar
    Apr 2005
    42
    224
    Wslaam
    Here in Lahore this year's model can be bought at around 450, but i think that the prices in karachi r cheaper then this.
    Turbo is an exhaust driven compressor which compress more air then the engine can inhale with the help of turbo thus it helps in inhaling more oxygen for bigger flame n more power. its property of the gas, that when it gets compressed it gets hot n hot air increses the chances of preignition(self ignition of the mixture b4 the intended time) so in order to cool down the compressed intake charge, intercooler is used.
    It is adviseable not to remove these things if they were factory fitted. because the engines which come fitted with intercooled turbo from factory have low compression pistons n by removing the compressor v would make the engine loose around its 50% power n even more torque.
    The ac itself needs, atleast 7-9 percent or may b more, engines power to work properly so on an engine which already would b generating 50% less power would loose another 8% power with ac.
    Yes a kit spesifically built for turbo application can b used properly wth this car.
    with a proper turbo kit one should not loose much power.
    Its a small car n a good conditioned 660cc modern turbo petrol engine can pull its weight very well around the city.
    But if ur mini is a CVT auto then make sure that u dont loose more then 7-10% engine power coz this lose of power can change the behaviour of the gear due to the reason of less oil presure through the governor valve of the gear which regulate the shifting pateren in accordance ot the presure applied on the gear oil from throttle. N All this can result in a premature failure of ur CVT auto gear.
    U r welcome
Closed Thread
