Results 1 to 14 of 14
Like Tree13Likes
  • 1 Post By ahmar.mirza
  • 1 Post By noman8ff
  • 2 Post By sherkhan
  • 4 Post By noman8ff
  • 1 Post By waqqasnasir
  • 1 Post By sherkhan
Thread: SJ410 suspension
    ahmar.mirza's Avatar
    Sep 2014
    40
    Default SJ410 suspension
    I have recently got a suzuki sj410. The ride quality is not very comfortable due to its current suspension setup. I wanted to know if its easy to change its suspension to that of siera and will it make it more comfortable? And any ideas how much will it cost to change the whole suspension and will it be bolt on or do i need any alterations?
    I would appreciate replies from experts regarding it as I am totally new to this 4x4 thing and I want my jeep to be safe for off-road and as a daily runner.
    qwertypoiu's Avatar
    Feb 2007
    29,128
    153 Post(s)
    2 Thread(s)
    Its better not to touch it and live with it, there is no great solution to its hard suspension.
    RIP
    noman8ff's Avatar
    Oct 2007
    41
    1,758
    10
    72 Post(s)
    the leaf springs are bolt on. get the original 3 springs and a jumper spring in front and 4 + 1 at rear. also get original good quality shocks and it will to some extend improve the set up. also mention the types of tires (tire size) and rims u r running. if not clear pls call me on 03335119925 and i'll explain.
    Sep 2014
    40
    At the moment its having stock tires n rims. But i definitely would go for wider tires and some better looking rims. Any suggestions on that as well?
    Quote Originally Posted by noman8ff View Post
    Sep 2014
    40
    Plus the setup you mentioned, any ideas how much would that cost? My plan is to first get comfortable suspension then upgrade the looks.
    noman8ff's Avatar
    Oct 2007
    41
    1,758
    10
    72 Post(s)
    so as i told earlier, get the original leafs and shocks and than will discuss the rest
    sherkhan's Avatar
    May 2007
    49
    60
    2 Post(s)
    AoA,
    @noman8ff and qwertypoiu
    I have the same question and many ppl. have converted to Jimny/Sierra coil spring suspension and infact am going today to a mechanic who claims has done this kind of alterations.
    What are the drawbacks as you both experts are advising against it?
    It will be very helpful if any of you guys explains in detail the pros n cons, I love my first buy 89' SJ410 and not getting any younger so I need a softer ride
    It's the best rough n tough ride in city traffic jams and I call it boxer as has broken many rickshaw noses
    Thanks
    waqqasnasir's Avatar
    May 2010
    31
    1,106
    18
    10 Post(s)
    2 Thread(s)
    @noman8ff sir
    I am also interested in this alteration.... if this is advisable and total cost estimate..
    Winning is not every thing .... its the only thing
    noman8ff's Avatar
    Oct 2007
    41
    1,758
    10
    72 Post(s)
    Hmmmmmmmmm
    A very difficult and tricky thing to explain.
    The problem of hard suspension of an sj 410 can be solved but it does have some negatives.
    Like the stock leafs are 3 in front and 5 at rear (less the jumper leaf). So if you just make them 3 in front and 4 genuine springs in rear, the ride will slightly improve but the problem you will face is that the veh will get lowered once loaded (means 4 to 5 ppl) and the rubber pieces on top of the tubes will hit the frame.
    Same is the case with the coil springs. The ride wil improve but once loaded it will be a problem.
    And this is the problem with all light weight vehicles that more leafs make them hard and both less leafs and coils make the ride soft but less load bearable.
    What i used to do is to keep stock leafs, means 3+5 and would use 15" rims and bigger tires so that on events of IJC i can reduce the tire pressure and get a comfortable ride. The stock 6X16 general tires can also work bot if u keep less than 18/ 20 pounds of air pressure.
    Going for coil spring is just as you reduce the no of leaf springs. And just to explain, if you keep only 2 leafs at front and 2 at rear, the drive will be like a crown, but than weight lifting will be a problem. I hope something is clear?
    Just to give you an example, a person went to a skin specialist to show him pimples on his face. The dr asked, what do you eat? And the reply started with 5 eggs in the braekfast followed by a long list of hot meals. The dr asked why do u eat so much of protein and the person replied that he does body building also. The dr than commented that, " either you can become Shah Rukh Khan or Arnold".
    May 2010
    31
    1,106
    18
    10 Post(s)
    2 Thread(s)
    Shahrukh or Arnold ...
    very nicely explained
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Question
    @noman8ff what is the cost of getting a decent Suzuki 410/413 these days? One that requires no work and all.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
  12. #12
    noman8ff's Avatar
    Oct 2007
    41
    1,758
    10
    72 Post(s)
    Quote Originally Posted by sarmadqureshi View Post
    Around 4 if it's stock and 4,50 of it has power steering and front discs/ survo. And soft tops have no price tags.
  13. #13
    sherkhan's Avatar
    May 2007
    49
    60
    2 Post(s)
    Thank you very much noman8ff for a very thorough explanation and sharing valuable info.
    Well, for me it certainly works as 90% it will be me only or 1+1,I hardly will carry any heavier load.
    Though I've seen pictures and videos of some extreme mods done to suspension and some very good off roading with SJ410s.
    My jeep has seen a lot of action in early 90's,before these rallies where started we were doing some extreme stunts beyond jeep's limit and used to race on chenab ,ravi and indus banks while hunting tours and it was a lot of fun
    The tiny 970cc engine and it's very impressive 4x4 pulled a bogged 3door 85 Pajero as we did not have any winches.
    In city it's not a problem but if on a broken road it feels rather bumpy though I'm having 235/70/15 tyres (The 2C engine can easily drag low pressure tyres)
    I'm planning to go for a G13bb engine with either original or Jimny/
    Samurai transmission + suspension and might go for adjustable long travel heavy duty softer shocks.Front disc brakes too.
    I've seen a sample of 86 model jeep and test drove it yesterday,there was considerable difference in ride comfort.According to the owner it was 98 model suspension however the engine/gear was original.
    I do not have any plans to lift it but lift kits for SJ410 are available (those might be for leaf springs).
    There are plans for power steering and some other cosmetic changes as well.
    I might also change the original front seats to some comfy car's bucket seats and rear jump seats will be cut short for 1+1 or may be no rear seats at back
    Anyway thank you very much for your replies.
    cheers!
  14. #14
    noman8ff's Avatar
    Oct 2007
    41
    1,758
    10
    72 Post(s)
    Quote Originally Posted by sherkhan View Post
    cheers!
    my pleasure brother.
