Page 6 of 6 FirstFirst ... 456
Results 101 to 103 of 103
Like Tree34Likes
Thread: suzuki sj410 4age silvertop swap
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    Default suzuki sj410 4age silvertop swap
    My dream to get a part in chollistan desert jeep rally in jimny 1.3 to 1.6 category (D) thats y I have buyed a suzuki jeep 85 model steel body which is converted to soft top. Currently it got 2c engine in it with some unknown big long gearbox. i want to make a serious power under the hood with no issues so it will help meh in qualifying the track in the deep dunes without power loss. i am thinking to put a 4age silvertop 168 hp in my suzuki jeep and i want you guys to help meh with the conversion like:
    1. which gearbox will best fit to the 4age engine and relieble too....
    (someone told me to cope with t50 ae82 rear wheel drive gear with straight bolt fit up) second option is hilux or surf gear or w58 rwd supra 2500cc gear.
    2. second probem is which 4x4 gear will be able to fit??? surf or hilux 1 or oringal suzuki sierra 8v 4x4 gear???
    i know if we fit 16 value jimny or elk model gear with the engine with a plate thn 4x4 gear will directly fit to it..
    3. which shaft and differential should be used??? the orignal sierra 1 will b ok but its under power and chance to break. many people suggested the hilux shaft and differential but its noisy due to it wieght and bigger and it touches the body which creates noise but its very strong as compared to orignal differential.
    plx help meh with this conversion i shall be very thankful to u guys. m really dipressed :-(
    i dun wana go with the suzuki engines as they r under power and when they get hot coils melt up and speacially dohc engines starts missing up and gti 1.6 baleno 1 too get missing when it gets hot....
    they r max 113 hp peak but 4age will be the most killing thing cux of its high reviving and toyota engines does not have these coils heating issues too...
    :-) i am waiting for u guys to help in order to start my project asap :-)
  2. #101
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    1 thing I should know for sure if any1 tells what's specific transmission and 4wd gear will attach to 1.6 dohc swift engine??? as jimny 2008 gear will attach to 1.3 swift engine....kiya 1.6 ko b attach ho jaye ga??? and 4wd phir kiska lagay ga sj410 ko??????
    kisi k paas jawaab hai eska?
  3. #102
    saboor73's Avatar
    Oct 2013
    10,545
    25
    349 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by kenblock3 View Post
    Engine bay nai mounts alter karne pare gas baki Sab awd shaft deferiall ka itna masla nahi hoga
  4. #103
    kenblock3's Avatar
    Nov 2014
    Bahawalpur
    25
    112
    u r ryte saboor Bhai....actually m starting my project in July as payments HV been made through this period and I dun wana get things ordered by mechanic as they bc's bC's :p
    I want to get these things from Peshawar so I need a list of these items so I can negotiate n get it by myself bro....
    saboor Bhai warna mechanic ne tou sab fit kr dena hai n he will charge it but maza nae ana na phr bro ;-)
    Tum sab bhaion ki madad chahiya bas...uknow m begganier :-)
