Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By akifjanjua
  • 2 Post By SuhaibKiani
Thread: 1KZ-TE Kash ma Kash
    sarmadqureshi's Avatar
    Dec 2007
    40
    1,599
    Exclamation 1KZ-TE Kash ma Kash
    Crowd Sourcing a solution to a kash ma kash!
    Vehicle:
    1996 Prado SWB
    1KZ-TE
    154,000kms
    Kash ma Kash ? engine overhaul?!
    Should a compression test be done?
    What are the ball park figures that come out from the test that mean one should get the engine over-hauled
    Should one get an over-haul, on the slightest bit of oil seepage &/or smoke or wait till it goes to heavy smoke &/or excessive oil consumption
    I use mine as a daily driver, thus don?t want surprises either side of my journey
    My maintenance is on a 3,000kms or 3 months whichever comes first, basis and its usually the later, where I have clocked about 1400 kms between oil changes.
    Lately, my morning starts were being troublesome, I thought of compression issues, but it turned out that my battery of 2 years, 2 month & 25 days had completed its life. Now that thing is stuck in my head and I cant decide whether I should go for an over-haul or not.
    What say you experts.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    On a turbo diesel like 1KZTE, oil consumption and blue smoke can be a possible turbocharger failure. Inspect the turbo charger first for excessive play and excessive oil in intake... a layer of oil is normal.. however turbo should not be throwing oil in intake.
    If its 154k original miles.. i doubt the compression would fail.. diesels are pretty strong if properly maintained... a compression test would tell the actual condition.
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    @sarmadquereshi
    1KZ is a tough cookie unlikely to die out at just 150ks......
    However given the scenario of buying a second hand car in the land of the pure....
    Meter reversals are kinda viral.....
    Oil consumption....
    Litmus!
    MEN DO IT AT DAKAR!!!
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    " Should one get an over-haul, on the slightest bit of oil seepage &/or smoke or wait till it goes to heavy smoke &/or excessive oil consumption"
    Out here, I recommend running it to the ground before opening it up. If maintenance is proper you could run it for a long time without surprises and even the oil consumption should settle into a predictable pattern.
    "If YOU don't believe in what you're doing it'll never work."
    Dec 2007
    40
    1,599
    Quote Originally Posted by MITSU_MAN View Post
    @sarmadquereshi
    Oil consumption....
    Litmus!
    I trust the mileage since I've known the vehicle from the time it landed in the land of the pure...
    P.S. Where is Sunday's meeting point shifted to ?
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    Quote Originally Posted by sarmadqureshi View Post
    Then need not worry.....
    Unless you have doubts on the lubricants provision source in the land of the pure.....
    150k and should keep ticking.....
    Between Emar and DHA Cogen on the beach....
