Results 1 to 11 of 11
Like Tree6Likes
  • 4 Post By MITSU_MAN
  • 1 Post By joinami
  • 1 Post By devils_smile
Thread: 1KZ TE engine overhaul or Swap
    hassan211's Avatar
    Jul 2014
    84
    Default 1KZ TE engine overhaul or Swap
    Salam
    I have 97 prado with 1Kz te engine...it consume 2 liter Mobil oil with in 1000 Km and gives halka blow according to mechanics. Now i am thinking of swap the engine with other less km driven 1kz. Should i go for swap ? Does 1kz swaps are successful ?
    OR
    Is there any other option ?
    hassan211's Avatar
    Jul 2014
    84
    bump...
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    Change your mechanic....
    'Halka Blow'.....
    With 2 litres of oil consumption....
    And also ponder over your oil brand, source and grade.....
    An oil burner at this rate should give you serious starting up issues by now......
    Poor compression on 1KZ and 1KD are known for their poor start ups......
    MEN DO IT AT DAKAR!!!
    hassan211's Avatar
    Jul 2014
    84
    i use Zic 5000 10W/40
    and yes i am facing starting issue as well it takes longer time to start up
    MITSU_MAN's Avatar
    Apr 2009
    47
    872
    27 Post(s)
    Quote Originally Posted by hassan211 View Post
    Then that 'Halka Blow' theory stands incorrect......
    Rebuilds are only good if you have a qualified mechanic and an equally matching machinist.....
    And have the luxury of 'REAL' original parts sourcing.....
    Kabli options hold good if you have a donor half cut to register the car's mileage....
    And btw, better lubricant options are available than your current preferred brand....
    joinami's Avatar
    Mar 2009
    Adelaide
    38
    2,949
    5
    95 Post(s)
    28 Thread(s)
    Rebuild only if you get hold of complete re build kit including new head bolts and every thing .
    How many KMs your car have done ??
    As I have a experience if having a 1kz with more than 400k KMs and still going strong .
    Old is Gold
    Sulfide by Nature ....Trained & Tuned @ Toyota,,,,,,
    devils_smile's Avatar
    Feb 2009
    Bonn
    26
    4,583
    171 Post(s)
    6 Thread(s)
    I would move to Caltex DeloGold 10W40
    My 1985 Mercedes Benz W201 190D (DIY's, Detailing and Photo-shoots)
    http://www.pakwheels.com/forums/members-member-rides/207432-my-mercedes-c-class-w201
    hassan211's Avatar
    Jul 2014
    84
    Quote Originally Posted by MITSU_MAN View Post
    qualified mechanic is difficult to find and i have no mechanic whom i can trust
    half cut option would be better...
    kindly recommend any better brand
    hassan211's Avatar
    Jul 2014
    84
    Quote Originally Posted by joinami View Post
    Car is only driven 90000 kms maybe previous owner reversed odo meter but over all condition of the vehicle is very good
    Engine also runs fine turbo and inter cooler is also OK but car gives lot of black smoke some times start up is also long and if we open oil cap it throws little bit oil
    hassan211's Avatar
    Jul 2014
    84
    i am worried because of smoke and oil consumption Recently only 4 liter oil comes out from engine during oil change
    sohaib474's Avatar
    Mar 2014
    5
    sorry for a bit off topic. How much does it cost for an engine rebuild or a swap?
