Results 1 to 6 of 6
Thread: Land Cruiser 1990 Model reducing oil
    goshi_mirza's Avatar
    Mar 2008
    43
    72
    Default Land Cruiser 1990 Model reducing oil
    Hello friends aoa my LC LJ71G reducing one litre oil after 2000 kms.What the options do i have?Should i go for head work including replacing valve seals , replacing rings, pump work and timmimg or I how much more kms i can run on same engine till overhaul? Engine is 2LTE.
    Shahzad
    Mar 2008
    43
    72
    bump....................51 views and anxiously waiting for pakwheelers specialists
    Shahzad
    SuhaibKiani's Avatar
    Jan 2006
    Select City
    41
    4,899
    5
    61 Post(s)
    You can run the engine for quite sometime if you don't abuse it and minimize engine load (Not much ac, no offroading, no towing, no road racing, hard acceleration etc). A liter in 200 kms is when you should be really really worried (not kidding, just an inside joke here...)
    If your asking whether to replace or overhaul, its is a long discussion, nevertheless both options have pros and cons. Depends on what your more comfortable with in the end....
    "If YOU don't believe in what you're doing it'll never work."
    Mar 2008
    43
    72
    If I dont abuse then can i have another hundred thousand ( 100,000 ) kms. Thanks Suhaib Kiyani.Grateful for your prompt reply and finishing my worries
    Shahzad
    Mar 2008
    43
    72
    I was asking by doing the head works that is valve ,seals and ring replacement can i overcome this problem at this stage.Need your advice bros
    Shahzad
    Mar 2008
    43
    72
    bump.............................................. ........................
    Shahzad
