Results 1 to 14 of 14
Thread: Larger Intercooler + Silicone hoses/ Pipes
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Default Larger Intercooler + Silicone hoses/ Pipes
    I need a larger than stock intercooler for my Defender 110. Also need all related silicone hoses + pipes etc.
    Are these available any where in Pak? Dubai ? USA?
    Assalamwalikum,
    Sajidd
    Pakwatan Explorer
    psyb0rg's Avatar
    Sep 2005
    San Jose
    29
    3,022
    You can find 'em at Shershah or you can even try the perfromance shops here is KHI, they might have large ones...
    "The rough, hard idle swells up and out from under the car, ricochets off other cars, and rams into the ears of the driver, the spectators. You think twice about a 383 Road Runner, but a hemi only once -- and let it pass."
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Racer..many thanks for the links, I am in touch with these companies. Notice that they are all UK based, I am at this point seeking USA or DUbai based company.
    By the way how can I edit my post ? instead of writing "larger" , I have written "larer"...
    Maybe the admin can correct it.
    Salaams
    Sajidd
    Pakwatan Explorer
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    @Sajid
    yes most of them are UK companies, as for Dubai I have look. Cannot promise you anything
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Racer, thanks for the help..and no need to promise..
    Also can you share your experience on having double shocks? I am seriously thinking of having twin shocks mounted on both front and rear. Do you have any experience in this regards?
    Sajidd
    Pakwatan Explorer
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    No epxerience on dual shocks but me Sameer did see one in the Autoshow on a Dakar rally prepared vehicle. What would you like to know ?
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Racer,
    I wanted to know how the set up works. I have been told that one set of shocks work as "primary" shocks and the second as "secondry". Some one else told me that the load is divided equally. So I am not sure how the shocks are mounted and how the load is divided.
    Right now I have ARB Emu set up, should the second set of shocks also be same as what I have ? or can I go with something more tough like this
    http://www.4wdconcepts.co.nz/Tough_Dog/Shocks/tough_dog_shocks.htm
    Or Bilisteins? Rancho?
    Let me know your thoughts.
    Regards
    Sajidd
    Pakwatan Explorer
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    @sajid
    The setup I saw had a equally divided load type set up. If it is a Primary/ scecondary type setup they should be on different height controls.
    Equal load setup
    Larger Intercooler  Silicone hoses Pipes -681073
    Primary secondary setup
    Larger Intercooler  Silicone hoses Pipes -681074
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Hi Racer,
    Did you up load two or one pic? I can only see one, the equal load pic.
    Anyway, I have written to ARB and will call them tomorrow and find out what they suggest in regards to twin shock mount.
    I am ok with both set up, equal or unequal. In fact given that my current shocks are fairly soft, it maybe better if I go for more of the same, rather than introduce hard shocks on the suspension, as that may result in the hard shocks doing all the work.
    Regards
    Sajidd
    Pakwatan Explorer
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    Loaded 2 pics but error in the name so renamed and now ok
  12. #12
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Racer..the primary/ secondry set up looks complicated.
    I will visit Khan Motors tomorrow and ask them if they have done this kind of work on any 4x4.
    Sajidd
    Pakwatan Explorer
  13. #13
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    @Sajid
    Regarding using two different shocks, I also would not advise it as it make one work harder then the other, as you mentioned.
  14. #14
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Racer.. I think equally divided load set up is what I will go for...but first need to find shock mounts that can accmodate two shocks..
    Salaams
    Sajidd
    Pakwatan Explorer
