Page 2 of 9 FirstFirst 1234 ... LastLast
Results 21 to 40 of 171
Like Tree2Likes
Thread: Project Jeep Willys M38
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Default Project Jeep Willys M38
    Wanted to share this Jeep with members.
    It is Willys M38 1951.
    Project Jeep Willys M38 -488812
    Project Jeep Willys M38 -488813
    Project Jeep Willys M38 -488814
  2. #21
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    @All
    Thanks for comments
    @IKJ
    Orginal engines are not easy to find, lets hope for best.
    @Voyager
    Thanks for suggestions. Plan is to keep it as stock as possible.
    @ahsanmq
    Denting & painting would be around 15000/-
    @nascar
    Estimated that total spending would be 80,000.
    Lets see if original engine could be found some where.
    Original suspension and drive train.
    No plan to sell.
  3. #22
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Hi, please do not change the original tail lights they are waterproof. a lot of original parts of your jeep are available in pindi you must explore that. secondly if the tokens are short you must show the jeep before restoration to the authorities to wave off the tokens.take care
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
  4. #23
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Rear axle rebuild
    Axle housing was centred by previous owner and shafts also cut & welded. So housing & axle shafts were useless. Only differential was re-usebale.
    Dis-assembled, cleaned, greased and adjusted all parts.
    Housing changed (from Bilal Ganj)
    New axle shafts
    New seals
    New differential bearings
    New yoke
    New wheel bearings
    Painted
    Project Jeep Willys M38 -685064
    Project Jeep Willys M38 -685065
    Project Jeep Willys M38 -685066
  5. #24
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    @Jeepaholic
    I love these lights, so no plan of tail & front lights change.
  6. #25
    R.I.P. Follow
    aridsoul's Avatar
    Aug 2003
    39
    8,496
    Important Question.....are you converting it to RHD or are you keeping it LHD ???
  7. #26
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Left hand drive!
  8. #27
    Qaisrani's Avatar
    Dec 2005
    Other
    3,910
    6 Post(s)
    Very nice project .
    I don,t believe in taking right decisions, i take decisions and make them right !
  9. #28
    ahsanmq's Avatar
    Jun 2004
    41
    4,351
    2 Post(s)
    why left hand????????????????????why not RHD
    Ahsan Qureshi
  10. #29
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Front axle rebuilt
    Old differential was rusted due to non-use and oil drain.
    Dis-assembled, cleaned, lubricated and adjusted all parts.
    Differential changed (from Bilal Ganj)
    New seals
    New wheel bearings
    New king pin bearings
    Knuckle seals
    Spindle bush
    Painted
    Project Jeep Willys M38 -685679
    Project Jeep Willys M38 -685680
    Project Jeep Willys M38 -685681
    Project Jeep Willys M38 -685682
  11. #30
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Thanks Qaisrani !
    @ahsan
    1-For sack of originality
    2-Needs extensive alterations of steering box, tie rods, linkage, dashboard, pedals, etc.
  12. #31
    shahraiz's Avatar
    Feb 2005
    29
    38
    Nice Progress ...Keep It up
  13. #32
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Leaf Springs Rebuilt
    Spring packs dis-assembled, cleaned & lubricated.
    Changed centre bolts, pivot bolts, bushes, shackles, grease nipples etc.
    Rear U-bolts also changed as per original specs.
    Spring packs painted after assembly.
    Body denting complete by the time.
  14. #33
    ahsanmq's Avatar
    Jun 2004
    41
    4,351
    2 Post(s)
    bhai jan plz upload new pics etc. v r waiting...............
    Ahsan Qureshi
  15. #34
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Chasis Back on Wheels
    Axles, springs and shock absorbers re-attahced with frame.
    Many nut bolts changed. It is hard to find bolts with US standard threads but found a 'kabaria' in Badami Bagh having these bolts.
    Project Jeep Willys M38 -686275
    Project Jeep Willys M38 -686276
    Original C-type spring shackles
    Project Jeep Willys M38 -686277
    Chasis number stamped on frame. Not clear in this photo due to reduced resolution.
    Project Jeep Willys M38 -686278
  16. #35
    psyb0rg's Avatar
    Sep 2005
    San Jose
    30
    3,022
    Great! got more pics?
    "The rough, hard idle swells up and out from under the car, ricochets off other cars, and rams into the ears of the driver, the spectators. You think twice about a 383 Road Runner, but a hemi only once -- and let it pass."
  17. #36
    ahsanmq's Avatar
    Jun 2004
    41
    4,351
    2 Post(s)
    @saad_q
    ohhhhh thanks for uploading...............:-)
    Ahsan Qureshi
  18. #37
    raja_aftab_yasin's Avatar
    Oct 2005
    35
    5,186
    Good work one day you will be succeed?
    NAMAZ ADA KARO ISE SA PHALA KA THUMARI NAMAZA JANAZA ADA KIA JAY
  19. #38
    R.I.P. Follow
    saad_q's Avatar
    Dec 2005
    49
    369
    Thanks guys!
    @Raja sb.
    Is it a question or a compliment?
  20. #39
    Site Banned Follow
    uruleworld's Avatar
    Feb 2006
    Maryland (Washington Dc area)
    26
    1,067
    @ahsanmq
    i agree with you too
  21. #40
    ahsanmq's Avatar
    Jun 2004
    41
    4,351
    2 Post(s)
    @uruleworld
    thanks bro
    Ahsan Qureshi
