I came back from Dubai on 16th and checked that my Willys half-yearly maintenance is due. As I have short time after enjoying one week in Dubai therefore I drafted the work plan and took my MB for it’s the maintenance as following:
Started with the suspension check up. All the leaf Springs along with the Shock Observers were checked. Changed all the 24 bushings for Leave Springs. I was little concerned about the Leave Spring Plates so asked the guy to fabricate a custom made with thicker plates. This whole work took 5 hours and I was done for the day.
Next day (yesterday) I went for the following work.
1: Air Filter Change.
2: Fuel Filter Change
3: Oil Filter Change
4: Engine Oil Change
5: Gear Box Oil Change
6: Battery Water Level Check
Then I went for Wheel Balancing and Alignment. After these maintenance works now my Willys is all set for the up coming Spring/Summer Season and reporting for duty to cruise up all the way to Khunjrab Pass.
