Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Gas to Diesel Engine Swap
    zeelaf's Avatar
    Jul 2005
    41
    711
    7 Post(s)
    Default Gas to Diesel Engine Swap
    Gas to Diesel Engine Swap -509512
    Gas to Diesel Engine Swap -509513
    Want to do a Gas to Diesel swap , which engine should I put in and what else needs to be changed ?
    Twin cam sixteen Vaalve da sticker Nikki jeyee gaddi utte
  2. #21
    hasan.nqv's Avatar
    Jul 2010
    Rawalpindi
    296
    2 Post(s)
    sir Gas=Gasoline..........CNG i think is refered as CNG............atleast in my books......
  3. #22
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    1HDFTE - nothing else would be upto par - you would get about 280 lb/ft torque at 1400 rpm - cant argue with that power - peak hp would be 165 at 3400 rpm (it would feel like a train though)
  4. #23
    farazarif's Avatar
    Dec 2007
    1,154
    17 Post(s)
    I used to own a UN Spec LC 80 series with a 1HZ, no turbo, no fancy electronics, and it was extremely reliable, never ever let me down and I had never gotten stuck off-roading in it and it was also quite economical to run when compared to my previous vehicles with 13BT, 1KZ and 3L. I would strongly recommend a 1HZ.
