Results 1 to 6 of 6
Thread: Information Regarding SUV Auto Gear || 2 , L ||
    k1
    k1 is offline
    k1's Avatar
    Jan 2007
    Quetta
    29
    411
    5 Post(s)
    Default Information Regarding SUV Auto Gear || 2 , L ||
    can some one tell me
    whats the use and advantage of
    gear : 2
    gear : L
    on Automatic gears
    and the use of Over Drive ...
    thnkx
    Tomorrow Never Comes Until its too late..
    Tz 3400cc..
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    Depending which SUV
    The 2 gear on your selector is to stop your vehicle tranny from changing into higher gear then 2nd.
    L is the lowest gear you can select if you need on the selector and they are used for towing loads from standstill or not wanting to go into a higher gear.
    Overdrive is the highest gear that your auto tranny has which allows it help in fuel consumption and gain higher speeds.
    Do a search you will find a lot more then what I just said.
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
    psyb0rg's Avatar
    Sep 2005
    San Jose
    30
    3,022
    F1, long time no see!
    "The rough, hard idle swells up and out from under the car, ricochets off other cars, and rams into the ears of the driver, the spectators. You think twice about a 383 Road Runner, but a hemi only once -- and let it pass."
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    @psyborg
    I have been around What about you?
    k1
    k1 is offline
    k1's Avatar
    Jan 2007
    Quetta
    29
    411
    5 Post(s)
    i herd that
    while in gear 2
    ur SUV will acclerate a little fast
    and till to the speed of 70-90 kph
    and during that change ur gear to D drive
    is that corrrect
    gear 2 helps in acceleration
    i got 3000 cc prado 95
    Tz 3400cc..
    sharry1's Avatar
    Jun 2007
    30
    62
    yea its right
    see there r diffferent modes
    in d all gears are shifted
    in 2 @racer f1 has said
    in l low gears are shifted this is used for goin to heights
