Results 1 to 6 of 6
Thread: Delay in gear change in Landcruiser
    whatcarman's Avatar
    Oct 2004
    Auckland
    46
    1,025
    Default Delay in gear change in Landcruiser
    Here I have problem with 1991 Toyota Landcruiser vx ltd, 4200cc diesel.
    When engine is cold and it is driven, for almost 3-4 kilometers engine revs but gear changes with delay. I have taken it twice to mechanic in Rawalpindi, and he changed something and oil, it does help for 2-3 days but it goes back to same again.
    Someone said that it is a turbo proble, I am not sure what exactly this is. Anyone have idea of what to do and where to go in Rawalpindi.
    Thanks
    In the Land of Mordor where the Shadows lie.
    drmac's Avatar
    Sep 2005
    53
    244
    whatcarman check the gear oil filter as it might be clogged and as oil is more viscous when it is cold there is a delay in gear change.it is usually a metallic filter all u have to do is wash it and then put in fresh gear oil.
    hope this helps.
    charterali's Avatar
    Dec 2004
    76
    4,502
    14 Post(s)
    Change the Transmission Oil and Transmission Filter. I once had a similiar prob in LC.
    Thnxx..
    Jayala....
    alphaX's Avatar
    Apr 2005
    46
    882
    Whatcarman........my LC had the same delay in shifting, especially in the morning, causing the engine to sort of race engine a bit more than normal before shifting. Changing the transmission oil and filter fixed it.
    CAUTION: DSC OFF!
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    Well these are usually first signs of the Auto clutch pack being worn. Do as the others say and might help as it does in most cases other wise you need to replace clutch pack along with valve body and filter.
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
    whatcarman's Avatar
    Oct 2004
    Auckland
    46
    1,025
    @drmac, @charterali, @alphaX, Racerf1
    Thanks guys. Oil has been changed twice in last six months, last gear oil change was less than a month ago and mechanic also cleaned filter. But same again.
    Engine revs and vehicle moves, say for 400-500 meters, when I see that revs goes up to mark 3 but still it does not change the gear. One short term solution I found is take the gear back to manual mode on position 2, where it gives a shoot.
    Now as Racerf1 said to change clutch pack, valve body and filter, seems no other option if this is the only solution.
