Results 1 to 10 of 10
Thread: CJ5/CJ7 leaf spring configuration
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Default CJ5/CJ7 leaf spring configuration
    Hi All,
    I have the original late CJ5/CJ7 7 pack leaf springs (7 pattay) on my CJ5... the ride height is ideal.. but its a bit stiff on road... a little too bumpy.
    i want to make the ride a bit smooth but not compromising the ride height.
    i think placing 5 pattay in front and 6 in rear will make it better... what do u guys say?
    any experience?? i dont want to disturb the ride height
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    shani606's Avatar
    Oct 2006
    43
    1,984
    3 Post(s)
    http://www.parabolicsuspension.com/index.htm
    try this
    Zeeshan Riaz Chaudhry..Hunt,eat,sleep and Repeat...
    OffRoad's Avatar
    Oct 2006
    39
    2,214
    17 Post(s)
    akif,
    Reducing leaf spring will be a temporary solutiion.Two suggestions from my side.Either use Dihutsu Rocky Leaf spring (front & rear) it will improve the bump on the ride & it will cost u abt Rs:14000/- (front & rear both).
    1st try to rduce the cj5 original leaf spring & check the result.If it wont work than go for Rocky or like Hamza Jeep...It was very smooth & comfertable isnt it?
    "Fun Begins Where Road Ends"
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    @shani
    thanx bhai jaan... the suspension looks awesome... but with a lot of $$$$
    @offroad
    fahd bhai i hav researched a bit... CJ7 springs came in 5 front and 6 rear configuration... and then there is a heavy duty version with 6 front and 7 rear.
    Got similar comments on offroadpakistan.
    i am thinking abt removing the lowest of the spring.. it will decrease the height a bit.. so im still thinking
    how much would it cost to remove the lowest springs? can do an experiment if its not that costly labor wise.
    oodbalow's Avatar
    Jun 2006
    Select City
    40
    17,047
    4 Post(s)
    @ akifjanjua
    the labour of " kamani wala " will not be more than 300 to 500 rupees
    http://www.facebook.com/oodbalow
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    @oodbalow
    thanks bhai jaan for the good news... bhai ki bari jaan jati hai kharcha kartay..lolz... ajj kal mechanics bhi doctor hai saray... yeh kamani wala kafi sasta lagta hai
    i'll definately experiment now
    aik aur baat...
    i think rubber bushes are used by kamani walas.. anybody has any idea of polyurethane bush for daihatsu rocky... any experience of that.
    and anything abt greasable shakkles (jhoolay)
    yeh sab bhai ne google.com se parha hai
    oodbalow's Avatar
    Jun 2006
    Select City
    40
    17,047
    4 Post(s)
    @ akifjanjua
    bhai yeh 500 wala sasta lag raha hai to aap aesa karo 1000 tip day dena
    akif bhai for more precise handling and firmer control on ur jeep, installing polyurethane bushings can make an enormous difference because they help to maintain the right alignment of caster, camber and toe, even on rough or uneven pavement. another advantage of polyurethane bushings is that they r virtually impervious to oil and other road contaminants . i think u can get these from ur Diahatsu dealer
    Greasable shackles are basically shackle bolts with a hole drill down the center and a grease fitting on the bolt head. half way down the shaft of the bolt, a small hole comes out the side, allowing pressed in grease to come out of the bolt into the tube. the tube should have a small hole in it allowing grease to come out of the tube, and behind the polyurethane bushings. the grease will improve ride on and off road .
    moral of the story : jitna gurr dalo utna meetha
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    On an initial inspection... i found the leaf spring bushing shot ... with many chee chaa noises
    i think they were some desi rubber bushing that couldn't last... now im searching for Poly bushing
    where will i find poly bushes for rocky... someone told me new bushes aren't avialable... hav to stick with kabli
    @Voyager
    you hav had work on your jeep's kamani's... plz guide... where will i find good quality bushing? and how much?
    help help
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Got my kamani bushing changed... got genuine rocky bushing.. off course kabli...
    and the ride is much much better
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Update...
    not satisfied with the 7 spring configuration... i took out the 2nd spring from the pack this weekend
    and the ride is much comfortable.. less bumpy and there was no noticeable change in ride height.
