Results 1 to 4 of 4
Thread: @TLCFJ40 Lift block solution
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Default @TLCFJ40 Lift block solution
    here is the setup i was taking about.. but this is only for vehicles with springs over axles... not spring under axles
    @TLCFJ40 Lift block solution -523238
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    I like those King Shocks..
    Pakwatan Explorer
    TLCFJ40's Avatar
    Sep 2006
    37
    1,784
    7 Post(s)
    @Akif thnx bro... ill go with the jumper leaf solution lets c how that works...will update u on that one..
    Toyota All The Way !!!!!!!!!
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    i think jumper leaf setup will also not help much but you can try
