Results 1 to 5 of 5
Thread: LandiRenzo TN 1 SIC in Toyota SURF 2.7 vvti (A/T)
    Silicon03's Avatar
    Sep 2005
    35
    203
    Default LandiRenzo TN 1 SIC in Toyota SURF 2.7 vvti (A/T)
    Dear Experts!
    Your openion is required on installation of CNG in Toyota SURF.
    It has 3RZ-FE engine which is a 2.7 L (2693 cc) version built in Japan. Bore is 95 mm and stroke is 95 mm. Output is 150 hp (112 kW) at 4800 RPM with 177 ft·lbf (240 N·m) of torque at 4000 RPM.
    I have found following versions of Landirenzo CNG Kit.
    http://www.landi.it/layout.jsp?idz=10068&idtp=166&lang=3&idcomponente= 50&idprodotto=24
    Versions:
    TN 1/B SIC (standard): up to 100 kW
    TN 1 SIC (oversize): from 100 kW to 146 kW
    TN 2 C SIC (super oversize): from 146 kW to 169 kW
    TN 2 C/S: from 169 kW to 193 kW
    TN 3 SIC: over 193 kW
    TN 1/B SIC Turbo: for turbo-charger engines up to 154 kW
    I think the second one could be used with the SURF.
    tauseefmutwahir's Avatar
    Oct 2006
    Peshawar / Knoxville, TN
    33
    1,298
    i dont think they have the oversize and supersize diaphram's...
    Oct 2006
    33
    1,298
    Silicon03's Avatar
    Sep 2005
    35
    203
    any serious and expert comment please ???
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Contact Logas.
    i had a discussion with logas.. he said that two reducers can be used in parallel for larger engine HP.. coz oversize kits are not available.... i think this could work!
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
