Results 1 to 8 of 8
Thread: Crackling door Noises
    AsimAK47's Avatar
    Jan 2008
    34
    85
    Default Crackling door Noises
    Hi,
    I got a problem of crackling door /dashboard sounds in my car , specially on bumps and on uneven roads, I got Honda city 2001.
    Is there anyone who can recommend me a good mechanic or place in karachi to fix this ?
    Thanks
    mmumtaz's Avatar
    Oct 2005
    44
    249
    Go to ant denter and ask him to change "door pins".
    ansarghani's Avatar
    May 2005
    Peshawar
    1,527
    8 Post(s)
    i am also facing the Noise problem in my 1973 Mark2... don't know how to or where to fix it.
    @ mmumtaz
    door pins will only solve the door problems.
    '73 Corona MarkII...
    imtishal's Avatar
    Sep 2006
    42
    3,881
    11 Post(s)
    @asim
    please eleborate crackling sound from dashboard.
    Also visit https://www.pakwheels.com/forumreply_az_TopicID!82696~ForumID!31~pw.html. u might find ur solution there.
    Qaiser Pal,I have not failed.But found 1 of 10,000 ways which doesn't work.....Toyota driver "I couldn't repair my brakes,so i made my horn louder"..When i was born i was so surprised that i didn't talked to one and half year..since light travel faster then sound,people appear bright until you hear them speak..If u can't convince them,confuse them
    iceman_kimi's Avatar
    Apr 2008
    Rawalpindi
    32
    560
    You can also use WD-40 to oil hard-to-reach joints etc. to remove some of the sounds.
    AsimAK47's Avatar
    Jan 2008
    34
    85
    Door pins can resolve this issue ? I remember i have installed central locking in my car and soon after that im facing these irritating noises
    @imtishal
    Even on very small bump dashboard is making noises...like it goes over hard bump.....is it somewhat related to suspension ? how can i know that my car suspension is hard ?
    imtishal's Avatar
    Sep 2006
    42
    3,881
    11 Post(s)
    Most probably the security system installer did something under the dashboard while installing.As for the suspension,just presss down the car on each side when car is parked if u hear squicking sounds from rare suspension then oil the bushes.and for front u have to replace the springs i guess.
    AsimAK47's Avatar
    Jan 2008
    34
    85
    THanks i will check with person who have installed central lock
