Results 1 to 4 of 4
Thread: Car starts but wont stop when the key is taken out
    farazarif's Avatar
    Dec 2007
    1,154
    17 Post(s)
    Default Car starts but wont stop when the key is taken out
    Hi, I was wondering if someone can help me,
    I have an '85 Landcruiser which Im currently in the process of restoring,
    last night while driving back from my mechanic a strange thing happened,
    the engine starts, the car drives but when I turn the key to switch off the engine, it doesn't switch off, I even took the key out of the ignition and it didn't switch off!!!
    Could some body please tell me what's wrong with the car and how the problem can be alleviated.
    Regards,
    Faraz.
    "A car is just a car unless it's my car" - Faraz Arif
    Ghufrandurez's Avatar
    Sep 2007
    31
    273
    Yup BRov Itz nOt a bIg IIssue sAMe thiNg hAPend tO me a COuple Ov DAys BAk ..
    Itz AKtUAly Ur CUt Out pROblem ,, dAt GOt damaged due to sum wAter simply Go to sum electretion and say him tO chek dA cut Out related tO ur self N fan DAz it and remeba it will nOt Cost u mOre DAn 250-300 K
    Take cAre ..
    SpeedDemon's Avatar
    Aug 2004
    399
    A diesel engine does not require electrical input to keep running. The engine does not require an ignition system.
    When you turn off the engine, a diesel cutoff valve in the fuel pump physically restricts the diesel from flowing forward, and that is how the engine shuts off.
    Either this valve is faulty or the connections to it are not working.
    Cheers.
    If you haven't seen the future, you're not going fast enough!
    farazarif's Avatar
    Dec 2007
    1,154
    17 Post(s)
    Thanks a lot guys,
    and thank God it's not catastrophic,
    Im at the point now when even a puncture is considered to be sabotage and a huge catastrophy since the restoration process is very taxing on the mind and more so on the wallet but this sounds good.
    Cheers...
