Results 1 to 9 of 9
Thread: strange problem of gear shift-Pajero MINI
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Default strange problem of gear shift-Pajero MINI
    Hi dears
    My friend's pajero mini non tubo auto has a strange problem of gear shift. While driving upto speed of 70 km/hr, it feels that it should try to change to next gear but it cant do so. The RPM meter goes to the end means that it attains high RPM in low gear(3rd gear). In short, it is felt that it has no 4th or 5th gear, if it would have been manual. I have advised him to get computer checked(may be I'm wrong). Any one please let me know from where to get computer check in pindi-islamabad.
    Sugessions from Mini Becharo owners are appreciated.
    Thanks.
    alizzz79's Avatar
    Aug 2006
    37
    2,722
    8 Post(s)
    Bro it's manual or auto tranny ?
    if it's auto tranny then it has only 3 gears .. get the gear computer checked ... a frnd of mine was also having the simlar problm that it was not going above 80km/hr so he got the gear computer replaced and now it's rockin ... if u were in khi then i mite had suggested u the place but dnt know anywhere in rawalpindi : )
    regards
    Do You Know The Meaning Of Speed Lanes ???
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    Ali bhai it is auto tranny. I've mentioned it already. Any ways thanks a lot for reply.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    jeepaholic's Avatar
    Oct 2006
    Other
    49
    1,843
    8 Post(s)
    2 Thread(s)
    Hi I think I can help you, give me a call on 0300-5271101. Take care.
    To all the extreme drivers, please come offroad like ME to keep others safe on the roads.
    aamir567's Avatar
    Feb 2008
    Select City
    55
    11,953
    26 Post(s)
    7 Thread(s)
    JeePAHOLIC IS THE RIGHT MAN FOR THIS KINDA PROBLEM CAS HE HAS ONE mINI pAJERO
    -It is always Man behind the Machine.
    kewll's Avatar
    Jun 2004
    39
    122
    I have a problem of gear in my city steermatic. THe rpm drops in D or R mode when the engine is cold. PLease advice place where can i check my gear box. I have replaced throttle body but the problem is not solved.
    whatcarman's Avatar
    Oct 2004
    Auckland
    46
    1,025
    There could be folowing problems in gear box.
    It may need chamber cleaning and oil change.
    One or more plates could either be worn out or damaged.
    Not sure about computer problem.
    There is a guy in Rawalpindi, Waheed near chohr chowk, he runs a garage called Young Autos, it is on the left side of road when you travel toward peshawar from saddar. I had same kind of trouble in my LC's gearbox and first time he had a look on it, advised me to change gearbox rather than repairing it, which was around Rs 80,000 that time. I did not take his advice and did everything else to stick with same gearbox, even at the end I got it repaired but it did not work. So at the end after spending more than 80k on it and went back to him and got one replaced with a new version which was over 1 lakh.
    He is very expert guy and very well educated, will give you best advice.
    In the Land of Mordor where the Shadows lie.
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    @jeepaholic
    Thanks, I will call u later.
