Results 1 to 12 of 12
Thread: Nissan Patrol - 1991 ( Wobbling Problem)
    ziadshahbaz's Avatar
    Oct 2006
    44
    9
    Default Nissan Patrol - 1991 ( Wobbling Problem)
    Dear All,
    I would appreciate if you could provide some advice or guidance for the following problem.
    I have a Nissan Patrol, 1990 model, 5 door. I recently noticed that about 110 - 120 the steering starts vibrating. This problem originally started with the old dunlop tyres steering vibration) and it was discovered that the balance rod bush and stablizer link bush had to be changed which was done. After this the problem went away.
    However 2 months ago, the problem came very minorly and as these dunlop tyres were old we got them balanced and the problem improved. As the dunlop tyres were getting old and frequently punchered, I had them changed and noticed that after the change of tyres the problem is still there at the above speed.
    I have had the wheel balancing done twice from different places and from where I bought the tyres with the tyre wala and my mechanics present together. The problem went away for 3 days but it is back.
    I have had the suspension and shocks checked and they are fine as it was a suspension problem then the problem would not go away in the first place. The jeep has been rarely used off road few years ago.
    I would like to know whether any one has had similiar problems as I know that quite a few people on Pak wheels own Nissan Patrol / Safari and other SUVs. Also, any advice or experience sharing would be nice. Thank you for your time.
    qwertypoiu's Avatar
    Feb 2007
    29,130
    153 Post(s)
    3 Thread(s)
    get alignment done
    RIP
    akifjanjua's Avatar
    Oct 2005
    Rawalpindi
    34
    1,097
    35 Post(s)
    3 Thread(s)
    Steering shimmy needs to be dealt with carefully... i suggest check the following step by step
    1. Tire balancing
    2. All steering component, bushing and tie rod ends. Also check the wheel bearings and kingpins for wear
    3. Check brake disc rotors.. a warp rotor can cause this
    4. Steering shock.. it helps dampen this shimmy.. check if its working or try replacing it.. note this should be the last thign u do.. it will cover the problem not cure it
    any one of these components can cause a shimmy..
    75% of earth is covered by water... the rest by Jeep
    www.brokenknucklegarage.com
    spectra's Avatar
    Jul 2005
    40
    19,667
    303 Post(s)
    24 Thread(s)
    It can be the rim which is causing vibration
    Keep a cool head and wear seatbelts!
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    does it wobbles when you instant brake at high speed . your problem could be both wheels and suspension .
    any play or imperfection in wheels/hubs should not make the whole car wobble .
    1) check the bushes of panhard rod . its a dialogonal rod on front tube has bushes on both ends . try to replace rubber ones with tefolon ones . also you need to replace your steering damper/shock .
    are ther any oil leaks in ur engine
    he who seeks shall find or he who finds shall seek
    Oct 2006
    44
    9
    Dear All,
    Thankyou for your inputs. I have had the suspension, steering, shocks everything checked out and it is fine, as it has nt been also used as such off road. No leaks in engine, or differential area. Surprising thing is that it could be the rims as one of you also mentioned as they original and came with the jeep.
    However one thing which is strange is that when the engine is cold, it does give this problem. However when the engine is warm, as for the pass 2 or 3 days the jeep is being used quite extensively, there is no wobbling at even 120.
    I discussed the above with the workshop guys, they said there was no co relation between the warm engine and wobbling. Or may be the tyres are setting in....
    What do you guys think ????
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    only another member who have same jeep can confirm, to me this cold engine and wobble sounds strange
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    funduro's Avatar
    Jan 2008
    45
    167
    4 Post(s)
    add lift spacer under ur front springs . raise the vehcle few inches then tried .
    NissanSafari's Avatar
    Mar 2009
    26
    82
    Broda agar yeh masla sahi karwana hai tou merey pass gari ley kar aajaoo mein sahi karwa dunga....
    untame's Avatar
    Jun 2005
    268
    check your driving shaft, make sure the rubbers and the joints are in good condition
    Life is short, lets go Off Roading!!!
    Charged's Avatar
    Apr 2006
    591
    2 Post(s)
    Worn out universal joints/couplings in propellar shaft produce similar symptoms
    There ain't no mud deep enough and no mountain high enough when you've got a LAND ROVER
  12. #12
    Oct 2006
    44
    9
    Dear All
    Thankyou for your kind support. I have taken everyone advice and have had almost everything checked out as recommended. Mechancially, the vehicle is fine. It is the rims which obviously have not been changed in 18 years and there seems to be play as the ratings get off quite quickly twice in last week. Also the problem improves once the tyres are balanced. The problem as such is only starts after 110 - 120. From 0 to 110 it is fine...
    I am looking for the standard rims, as the alloy rims would put additional weight on the suspension. My tyre guy got two sets of the standard rims but there were no good at the time of balancing. he has requested me to give him sometime. However if anyone knows, then let me know.
    Thanks again.
