Results 1 to 6 of 6
Thread: O/D Light Blinking
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Default O/D Light Blinking
    1992 3 Door PRado
    Auto Transmission
    1KZ engine
    The O/d (over drive) light is constantly bliking. Can anyone tell me what the potential problem could be?
    Salaams
    Sajid
    Pakwatan Explorer
    Inspire's Avatar
    Jan 2008
    30
    604
    2 Post(s)
    Wiring problem in your A/T Gear where O/D button is there...
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Thanks. I hope thats all it is and nothing more.
    Will get it chaecked tomorrow.
    Pakwatan Explorer
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Salam Sajidd bhai,
    Do you feel any difference in throttle response after O/D light? like self kickdown or irregular gear changes?
    If yes then it might be Speed Sensor problem. If not then check out the solenoids and make sure that you have no short circuits in wiring. O/D light is Check light for Transmission like we have check light for engine.
    Best of luck
    Drive a Legend. Drive a Land Cruiser
    Saaduk's Avatar
    Oct 2007
    Peshawar
    1,412
    7 Post(s)
    Also check out your oil level and filter and make sure your oil cooler works properly.
    sajidd's Avatar
    Nov 2004
    46
    1,495
    8 Post(s)
    Saaduk, thanks for the valuable input. Have sent her for a check up.
    Hope its nothing major.
    Pakwatan Explorer
