1992 3 Door PRadoAuto Transmission1KZ engine
The O/d (over drive) light is constantly bliking. Can anyone tell me what the potential problem could be?
SalaamsSajid
Wiring problem in your A/T Gear where O/D button is there...
Thanks. I hope thats all it is and nothing more.Will get it chaecked tomorrow.
Salam Sajidd bhai,
Do you feel any difference in throttle response after O/D light? like self kickdown or irregular gear changes?If yes then it might be Speed Sensor problem. If not then check out the solenoids and make sure that you have no short circuits in wiring. O/D light is Check light for Transmission like we have check light for engine.
Best of luck
Also check out your oil level and filter and make sure your oil cooler works properly.
Saaduk, thanks for the valuable input. Have sent her for a check up.
Hope its nothing major.
