Results 1 to 4 of 4
Thread: Digital Mileage Reset / Correction
    allyjeff's Avatar
    Jul 2009
    46
    Default Digital Mileage Reset / Correction
    :: What is Mileage Correction / Recalibration / Adjustment / Reset ::
    Today’s cars use electronic dashboards with digital mileage displays. When the dashboard on a vehicle becomes corrupted, we can correct the mileage to the correct value.
    Specialised equipment allows us to adjust the mileage and re-program to the correct value, but it’s not just about equipment it’s having the knowledge and experience, which we pride ourselves with.
    Car data can be stored in many places on the vehicle in fact as many as 160 locations, it is normally stored on the dashboard on an EEPROM, to the light control module along with other places as well as the keys, and we will advise you at every stage of the calibrations. We offer a unique fully guaranteed service to correct the odometer reading and have your complete satisfaction in mind. Most times you only have one chance of getting it right so choose us with confidence.
    :: Any Question Ring ::
    0333 4002221
    :: www.mileagefixer.com ::
    sunny69's Avatar
    Jun 2009
    46
    40
    correction means, meter reading can be adjusted higher or lower side???
    air_explorer's Avatar
    Aug 2005
    31
    1,316
    @allyjeff
    Sir,I hope you wont help others in altering wrong odo readings.
    Valle!! the great with his YZRM1 looks more coool!
    allyjeff's Avatar
    Jul 2009
    46
    a mechanical dashboard and easier to fit into the car as there
    is
    no mechanical speedometer cable. This new technology has its own problems though. Electrical pulses in the cars wiring can cause the dashboard data, which is stored internally on an EEPROM (Electrically Erasable Programmable Read Only Memory), to become corrupted.
    This corruption could happen for a number of reasons
    • the vehicle battery was discharged and the vehicle had been jump started
    • the dashboard may develop an electrical fault
    • the dashboard may be damaged in a collision or through vandalism.
    In these examples, mileage displayed on the speedo is now incorrect.
    Dashboard
    correction may also be necessary where a replacement cluster has been purchased, either new or second hand. If it's a new one it will have zero miles on it. If it's a second hand one the mileage displayed is also likely to be different to the original thus requiring correction
