Results 1 to 4 of 4
Thread: Chevy's Avalanche............. What else you need.
    max_mirza84's Avatar
    Sep 2005
    Sialkot / Dubai
    32
    1,569
    Default Chevy's Avalanche............. What else you need.
    Chevys Avalanche What else you need -468698
    Chevys Avalanche What else you need -468699
    Chevys Avalanche What else you need -468700
    Chevys Avalanche What else you need -468701
    Chevys Avalanche What else you need -468702
    Chevys Avalanche What else you need -468703
    Chevys Avalanche What else you need -468704
    Chevys Avalanche What else you need -468705
    Vortec 8100 V8 Engine
    The Big Block Vortec 8100 V8 engine in Avalanche 2500 delivers 325 horsepower and 447 lb.–ft. of torque at 3200 rpm. The engine is matched with a Hydra–Matic electronically controlled four–speed automatic transmission with overdrive and has these standard features:
    Coil–Near–Plug Ignition System
    All Vortec V8 engines feature an ignition coil for each cylinder to precisely deliver a high–energy spark for lower emissions and higher efficiency.
    High-Strength Crankshaft
    A high–strength cast–iron crankshaft is internally balanced and has undercut and rolled fillets to reduce stress loads. This design provides quiet running and reduces maintenance.
    Electronic Throttle Control (ETC)
    ETC relays acceleration information to the Powertrain Control Module (PCM). The PCM then positions the throttle butterfly valve in the best position to help achieve smooth linear acceleration.
    A PCM utilizes computer technology to continuously measure driver inputs and behavior to marry (or match) power needs with the transmission shift schedule. This system collaboration ensures that the transmission never has to “search” for the correct gear, thus maximizing performance and efficiency.
    Sequential Fuel Injection (SFI)
    SFI is employed by all Vortec V8 engines and provides reliable starting in hot or cold weather. SFI also contributes to the smooth, refined operation of all Vortec V8 engines.
    Comments on how am i behaving please call 0800-9211420 and eat ****!
    wik_a's Avatar
    Apr 2005
    Select City
    11,407
    4 Post(s)
    Wow
    Great Truck. Love it.
    By the way what are its spec? can you put those up on this topic?
    nice work
    "Our coerced silence is the weapon that has been sharpened and brought to our throats" - Mohsin Hamid
    toofast's Avatar
    Sep 2004
    Chizhou
    18,163
    31 Post(s)
    Piece of ****. Test drove one and endup buying tundra. Drives like boat on water.
    Even if you are on the right track, you will get run over if you just sit there.
    spiderman's Avatar
    Feb 2005
    9,667
    52 Post(s)
    7 Thread(s)
    hey these are the pics from the brochure do you have its brochure?
