If yr used to heel toe this isnt a great car, heel donest catch the gas padel in time you keep hiting floor while toe on brake,,
great part was driving non stop. it donest tire the driver, i drove non stop long hours and wasnt tired at all, keeping in mind i havent driven long distances in yers.
the driver seat height adjust is nice feature thogh the meachanics are same as VW beetle lifting up the seat,, i keep to the lowest position to keep my legs straight, and steering tilt to lowest position too.
@bilal
it way better than handling compared to camry, i dont know what you drove but i drove 06 camry and tC and camry has more weight at rear of car plus probably longer wheelbase so handling will be different, plus tC comes with low profile wheels.
About 0 - 60 yr most welcome to drag yr camry with my tC provided we both dont end up sitting in jail....... lets see if i can beat the factory set 0 - 60 times:)
No but seriously tC in manual shifting handles corners well , stay in 4th and youll eat high powered heavy automatic cars, till there brakes start to heat up. i tried this in west pennsyl to mid penn on interstate at 2- 4 am.
knowing ifone installs TRD bars in frt and rear plus coilovers(lowered) and 1 bar turbo boost, you can have a 200hp small coupe with neat handling - that;s little moe power than 2zzge because you cannot turbo 2zz ge unless your in big investments into engine.
but driver's license has lot more value than fiddling with a tC in case one gets a ticket.
