universal 530
1982 - 1985
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Production:
</TD></TR><TR><TD class=tfld>Manufacturer:</TD><TD class=tdat>UTB/Universal
</TD></TR><TR><TD class=tfld>Factory:</TD><TD class=tdat>Brasov, Romania
</TD></TR><TR><TD class=tfld>Total built:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Original price (USD):</TD><TD class=tdat>$19,000 (1985)
</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Engine:
</TD></TR><TR><TD class=tfld>Type:</TD><TD class=tdat>UTB
</TD></TR><TR><TD class=tfld>Fuel:</TD><TD class=tdat>diesel
</TD></TR><TR><TD class=tfld>Aspiration:</TD><TD class=tdat>turbocharged
</TD></TR><TR><TD class=tfld>Cylinders:</TD><TD class=tdat>3
</TD></TR><TR><TD class=tfld>Valves:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Bore/Stroke:</TD><TD class=tdat>4.016x4.331 inches [102 x 110 mm]
</TD></TR><TR><TD class=tfld>Displacement:</TD><TD class=tdat>164.4 ci [2.7 L]
</TD></TR><TR><TD class=tfld>Power:</TD><TD class=tdat>53 hp [39.5 kW]
</TD></TR><TR><TD class=tfld>Cooling:</TD><TD class=tdat>liquid
</TD></TR><TR><TD class=tfld>Compression:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Rated RPMs:</TD><TD class=tdat>2400
</TD></TR><TR><TD class=tfld>Starter type:</TD><TD class=tdat>-unknown-</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Transmission:
</TD></TR><TR><TD class=tfld>Transmission:</TD><TD class=tdat>constant mesh
</TD></TR><TR><TD class=tfld>Gears:</TD><TD class=tdat>12 forward and 3 reverse
</TD></TR><TR><TD class=tfld>Oil capacity:</TD><TD class=tdat>-unknown-</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Dimensions:
</TD></TR><TR><TD class=tfld>Weight:</TD><TD class=tdat>4000 lbs [1814 kg] (4800 4WD)
</TD></TR><TR><TD class=tfld>Wheelbase:</TD><TD class=tdat>77.1 inches [195 cm]
</TD></TR><TR><TD class=tfld>Length:</TD><TD class=tdat>125.2 inches [318 cm]
</TD></TR><TR><TD class=tfld>Width:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Height:</TD><TD class=tdat>98.43 inches [250 cm]
</TD></TR><TR><TD colSpan=2> </TD></TR><TR><TD class=thdr colSpan=2>UTB/Universal 530 Tires:
</TD></TR><TR><TD class=tfld>Ag front:</TD><TD class=tdat>7.50-16
9.5-24 (4WD)
</TD></TR><TR><TD class=tfld>Ag rear:</TD><TD class=tdat>12.4-36
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Capacity:
</TD></TR><TR><TD class=tfld>Fuel:</TD><TD class=tdat>14.27 gal [54.0 L]</TD></TR></TBODY></TABLE>
3 point hitch:
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear Type:</TD><TD class=tdat>I,II
</TD></TR><TR><TD class=tfld>Rear lift:</TD><TD class=tdat>2650 lbs [1202 kg]</TD></TR></TBODY></TABLE>
pto:
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=tfld>Rear PTO:</TD><TD class=tdat>independent
</TD></TR><TR><TD class=tfld>Rear RPMs:</TD><TD class=tdat>540
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>UTB/Universal 530 Power:
</TD></TR><TR><TD class=tfld>Engine:</TD><TD class=tdat>53 hp [39.5 kW]
</TD></TR><TR><TD class=tfld>PTO (claimed):</TD><TD class=tdat>50 hp [37.3 kW]
</TD></TR><TR><TD colSpan=2> </TD></TR><TR><TD class=thdr colSpan=2>Mechanical:
</TD></TR><TR><TD class=tfld>Chassis:</TD><TD class=tdat>4x2 2WD
4x4 MFWD 4WD optional
</TD></TR><TR><TD class=tfld>Steering:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Brakes:</TD><TD class=tdat>-unknown-</TD></TR></TBODY></TABLE>
<TABLE class=tdData3 cellSpacing=0><TBODY><TR><TD class=thdr colSpan=2>Hydraulics:
</TD></TR><TR><TD class=tfld>Type:</TD><TD class=tdat>open
</TD></TR><TR><TD class=tfld>Capacity:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Pressure:</TD><TD class=tdat>-unknown-</TD></TR><TR><TD class=tfld>Valves:</TD><TD class=tdat>1
</TD></TR><TR><TD class=tfld>Valve flow:</TD><TD class=tdat>9.7 gpm [36.7 lpm]
</TD></TR><TR><TD colSpan=2> </TD></TR><TR><TD class=thdr colSpan=2>Electrical:
</TD></TR><TR><TD class=tfld>Ground:</TD><TD class=tdat>-unknown-</TD></TR></TBODY></TABLE>
