Results 1 to 4 of 4
Thread: interchangeable nissan parts???
    spanky_johnson's Avatar
    Mar 2005
    Peshawar
    31
    55
    Default interchangeable nissan parts???
    can neone tell me if the Nissan Sunny 1.3l engine parts can be put in the Nissan March 1.3l engine??? are these two engine parts interchangeable because basically i think its the same engine frm the same company!!
    Mar 2005
    Peshawar
    31
    55
    when i say engine parts, i mean the fan belts, timing belts, head waghaira.. other engine parts??
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    well if both the cars are of the same year then i think so... but if you are talking about the nissan that was available in pak , 93 model.. then a big no caz that is a carby and march is efi....
    its all about power to weight ratio...
    Racerf1's Avatar
    Aug 2005
    Select City
    14,753
    33 Post(s)
    2 Thread(s)
    the CG13DE from the March and Sunny GA13DE some parts might be interchangable but none from the E13 engine block or maybe avery few.
    "The value of life can be measured by how many times your soul has been deeply stirred." Soichiro Honda
