Results 1 to 11 of 11
Thread: Advice needed from experts, Coure 95
    trojan's Avatar
    Jul 2004
    29
    1,107
    Default Advice needed from experts, Coure 95
    Hello ..I have a coure 1995 ..my question is : it vibrates on initial pick up and sometimes it do sometimes not..I got it checked by mechanic and he told its a clutch plate problem ..But I m not facing any problem like heating ..pickup .just vibrating problem
    My another question is yesterday I drove the 2004 model coure and its steering is soo soft compared to my coure easy to turn ..
    If i change/replace my steering with the new coure steering ..will it give me same drive? ( easy moving /turnings )
    Suggestions required soon .
    n forever shall the wolf in me desire the sheep in you!
    fedd's Avatar
    Jul 2004
    Select City
    1,396
    2 Post(s)
    As for the first problem... check th Clutch Plate or the Pressure Plate... I guess there will be some problem with one of these or both. Can't say anything about Problem 2.
    Nowadays people know the price of everything and the value of nothing.
    Konichiwa's Avatar
    Jul 2006
    2,809
    as for the first problem well i had almost the same type of problem and well when i used to let go of the clutch in my cultus in 1st gear it made the vib noises and well at first i too thought that it was the clutch or the pressure plate but then it turned out to be the underpipe of my exhaust / siliencer (get that checked)
    as for the second prob well if ur talkin jus abt the steering WHEEL then it wont help try installin power steering itll set you back around rs.3000 hope this helps
    http://i.imgur.com/nMDe1.jpg
    testdriver's Avatar
    Mar 2006
    40
    4,682
    77 Post(s)
    4 Thread(s)
    Your first problem seems to be clultch/pressure plate problem. For the second problem, first of all check the tyre pressure or the tyre itself, then get checked the alignment.......
    Adnan's
    Daewoo Cielo GLX 1.6L E-TECII DOHC 110PS/5000 150N.m./3400
    trojan's Avatar
    Jul 2004
    29
    1,107
    sometimes it vibrates sometimes not .. and I know abt the exhaust pipe its leak ..and the person says that the silencer is "chowk" but does it really create the problem or is it pressure/clutch plate problem ?
    idk1's Avatar
    Nov 2005
    34
    426
    it sure does
    IDK 1
    tazzix's Avatar
    May 2006
    40
    754
    @trojan:
    About the steering you should give indus motors a call or better pay them a visit e.g. Toyota Defence Motors, they have highly technical guys who know what they are doing. Get advice from there, then try to find the parts as some remove from accidented cars.
    In my opinion it should be possible and something is between the steering and the shaft but not something which can be termed a true "power steering"
    Waiting for the day people start obeying laws of the road while on the road... sigh!
    portage1's Avatar
    Nov 2005
    hyderabad & Michigan
    10
    21,004
    37 Post(s)
    3 Thread(s)
    your power steering pump going bad.......my brother..............................
    I'm a freak who lost his mind in the busy world of today and takes his frustration by being funny with others
    robin's Avatar
    Jun 2005
    2,825
    coure does not have power steering, check the ball ball joints, and steering assembly/ends, need lubrication.
    beeberg's Avatar
    Mar 2006
    Select City
    33
    4,123
    brother relax
    go to some mechanic and ask him to take off its clay. he will wash it properly and fix it then you will enjoy the ride
    for the first problem. change your clutch plate else you must have to change your pressure plate too. though replacement of both will do majik have fun
    life style: pakwheels
    tazzix's Avatar
    May 2006
    40
    754
    @robin:
    agreed and that is what I said. However, you should go and test drive a cuore to understand what @trojan means when he thinks his steering is tougher than models 2004 and above.
