Dear @surrosh
Winters in Pakistan are not that extreme like in canada and america where it touch -25 ,30 ...... In Lahore and Karachi extreme winter means max (1-10) degree which does not creates problem in first start of the morning .... so 20-50 is ok and switching of engine oil is also not good for engine.
thanks!
Ok bro thnx alot n do u knw which spark plugs i should use in it
Sent from my iPhone using PW Forums mobile app
Dear @angelinside
You can use normal plugs by NGK/ DENSO ..... iridium plugs are good but not that necessary
Thnx again !!! N the 10-11 km/l u told me is it with ac or without ac?
Yes with ac
Plz give ur valuable iopinion for buying a new car among the following choices to be driven on petrol by a lady 25km daily (Priority is ease to drive and fuel economy)1) Corolla Gli 1.3l2) Honda City Aspire 1.3l3) Honda City Aspire 1.5lIt will be an up grade from CULTUS VXL.Waiting ur reply and thanking in anticipation.
Dear @afak14If lady is a single driver and sedan is not a requirement then go for Vitz .... It is comfortable , easy to drive because of AT gear and also fuel economic .......but if sedan is the requirement and manual is not an issue then better to buy a new city 1300cc
@cerwinvega is right but you should also consider move 2011(or above) models as they are CVT , Highly spacious and very much fuel efficient car with not compromise to comfort!
Thanks for ur reply, would u please comment upon fuel consumption of 1.3l city? Thanks a lot.
Thanks
Dear @afak14Manual city 1300 gives 12-13km /l in cit with ac
Reasonable price for a honda City 2005 manual 150k driven only 3 piece touchup , avg condition, white colourThanks in advance @cerwinvega
Bs only 3 piece touchup IT worth no more than 670-750
Sir ur comment on city idsi engine efficiency after overhaul because some of pak wheeler suggest engine swap as better option rather than overhaul as it does not work well after overhaul.
Dear @janjuarajaWell it is recommended only if you have a reliable source in bilal ganj Otherwise you will end up paying for a new engine and in return getting a weak engine .... Otherwise its better to get it overhauled with new genuine parts
Dear @huzaifa.haroon
Although it is very very difficult to give price estimation of a car without having a thorough examination but if i consider each and every thing of the car in perfect condition except 3 piece touch then i think it can fetch 7-7.25 lacs
is there own going on city new facelift model?
Dear @maddyboyCan't comment on this because it changes every hour .... Last time I checked it was 25k .... But I think it will be available without own in DEC due to no sales ....
Brother , the people are asking more then 9 lacs for the very same car in Islamabad !Even demand for the total repainted cars is not less then 850k , so i was confused as the car is not mine
