Results 1 to 6 of 6
Like Tree2Likes
  • 2 Post By Xulfiqar
Thread: what are the reasons of black smoke from cars
    nabeelkhan's Avatar
    Oct 2008
    86
    517
    10 Post(s)
    Default what are the reasons of black smoke from cars
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    black smoke is a sign of excessively rich fuel mixture
    nabeelkhan's Avatar
    Oct 2008
    86
    517
    10 Post(s)
    excessively rich fuel mixture? mixture of what? and why it happens? please tell also
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    gasoline engine requires 4 things to work
    1 air
    2 fuel
    3 compression
    4 spark
    the air and fuel are sucked in together - the fuel is sprayed/atomised into the air (doesnt matter if carby or injector) - if there is too much fuel compared to air - you get black smoke, the usual ratio of air to fuel ranges between 13:1~14.7:1
    if you get to 13:1 under no load - you get black belching smoke, if you go under this - e.g. 12:1 or 11:1 you stall out usually.
    nabeelkhan's Avatar
    Oct 2008
    86
    517
    10 Post(s)
    Due to what technical problem it happens? it mean the carbeurator being out of order or the ring pistons of engine being old or plug and points being damaged? root cause kya hoti he
    and thanks for the detailed answer. it is certainly helpful for a lamer like me
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,400
    131
    3988 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by nabeelkhan View Post
    for carburettors, its usually a blocked emulsifying passage in the carby, or inoperative secondary or flooded bowl, in EFI it can be many other items like bad air metering sensing, bad engine temperature sensing etc.
    It can also be bad compression in engine, stuck EGR, bad timing.
