Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By hash4u
Thread: Car AC blowing warm air at Fan
    Babar2437's Avatar
    Aug 2015
    178
    3 Post(s)
    Default Car AC blowing warm air at Fan
    I own a city 15 driven only 4000 km. today I started off in rain and cold weather and AC was blowing warm air. Only fan was on and AC was off. Then why warm air?
    Regards.
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    because heat cold setting was on warm
    Babar2437's Avatar
    Aug 2015
    178
    3 Post(s)
    No brother it was at neutral. Warm air was coming in both regulation and fresh air mode.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by Babar2437 View Post
    if the selector is at neutral (I am assuming in the middle of mix) - you will get warm air as some of the heater air is being mixed in, If you select it to full cold then it will completely close off the heater air channel.
    If you get warm air at full cold position then the air control doors in the HVAC box are being the problem.
    Babar2437's Avatar
    Aug 2015
    178
    3 Post(s)
    Yes you are right. It's giving warm air at centre of mix. So it's a normal thing :-)
    Thank you.
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    Thank you.
    yes thats normal.
