Page 1 of 6 123 ... LastLast
Results 1 to 20 of 106
Like Tree100Likes
Thread: Dos and Don'ts for Car Maintenance/Repairs
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Default DOs and DON'Ts for Car Maintenance / Repairs
    Guideline for posting
    .. keep it general
    .. keep it simple
    .. quote authority or reference where available
    .. correct, what proves to be wrong later
    .. avoid unnecessary discussion
    Thanks
    Examples
    - Do change engine oil once in 6 months even if prescribed mileage has not been achieved
    - Don't
    remove CAT (catalyst convertor), either clean it or replace it
    Purpose
    Of this thread is to share knowledge on everyday issues .. question where the advice is not clear .. a healthy sharing and discussion .. in a typical thread not everyone gets knowledge then sometimes contradictions end up in unwanted debates .. hopefully those elements will surface less here
    "You have not lived today until you have done something for someone who can never repay you."
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    - dont use low priced coolant it has chemicals which react and reduce life of cooling system components
    - dont put colored distilled water in battery
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    - cheap brake disc pads are usually hard and cause irregular wear in disc
    memad's Avatar
    Nov 2010
    39
    5,503
    180 Post(s)
    Don't run your car on mix of 2 RON type fuel. Eg mixing 87 and 91.
    Only use what prescribed by the manufacturer.
    usmanqadeer.education's Avatar
    Jul 2014
    Rawalpindi
    26
    214
    3 Post(s)
    What is the reason to avoid mixture of 2 RONs...?
    memad's Avatar
    Nov 2010
    39
    5,503
    180 Post(s)
    The throttle body do not require adjustments and it is not necessary to open radiator cap and brake fluid caps for daily/ weekly check.
    The repairs need to meet the manufacturers specs with out short cuts.
    wasf's Avatar
    Dec 2007
    39
    545
    36 Post(s)
    Quote Originally Posted by Naweed View Post
    What about this coolant?is it cheap quality too?150/bottle.it claims to be produced from last 30 years
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Do change dot 4 fulid (clutch,brake etc) every year
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Don't spray oil underneath car
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3991 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by wasf View Post
    Buy good quality coolants - This one has nothing to its name, no manufacturer - nothing. even their website is useless.
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    dont use GL-5 spec oil in front wheel drive gearbox or with synchros...use GL-4 spec instead.
    dont use api sl or lower spec oil in CAT equipped car
    Dont remove thermostat and dont make fan direct
    dont use 20w-50 oil just on mech sayings
  12. #12
    aliusman420's Avatar
    Nov 2006
    6,935
    97 Post(s)
    2 Thread(s)
    Don't wash the car with surf or similar detergents, use a good wash & wax shampoo along with a premium wash mitt.
    Never dry dust the car under any circumstances.
    Always use premium products to nourish the paint, if you can pay for the car spend some money for its proper care too.
    8th Gen Mitsubishi Lancer 1.3 GLX 2006; 3rd Gen Toyota Prius 1.8 S-Touring 2010; 11th Gen Toyota Corolla 1.3 GLi AT 2014.
  13. #13
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    very positive response on thread .. thanks
  14. #14
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    not recommended, buy toyota or honda branded coolant .. price est 3-4k.. make sure there is no leakage in sytem and no engine overhaul due in near future or it will be a waste of money
  15. #15
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Quote Originally Posted by saboor73 View Post
    thanks .. a very pertinent point .. oil and diesel mix sprays reduce life of rubber bushes .. sludge forms underneath since this mixture acts like glue .. moisture in this sludge causes early rusting
  16. #16
    DUDE007's Avatar
    Oct 2011
    2,034
    104 Post(s)
    A little knowledge is dangerous. Know what you have to do and understand the concept fully so any mishap can be dealt with.
    Engine oil isn't the only fluid in your car. There is brake oil, clutch oil, power steering fluid, gear oil, ATF. Every oil eventually breaks down and needs to be replaced/flushed.
    Enviado desde mi GT-I9500 usando Tapatalk
  17. #17
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Quote Originally Posted by Mirza967 View Post
    removing thermostat and direct fan causes engine to attain desired temp late .. this causes extra wear since oils and engine parts are designed to work more efficiently on a certain temp ... in short the life of such engine would be under 100k kms ... this explanation is for others who read ur post .. thanks for sharing
  18. #18
    Mirza967's Avatar
    Oct 2011
    23
    242
    3 Post(s)
    dont tow the car with automatic transmission otherwise tranny will be damaged....it can be done only at 20 kmph for 2-3 kms.
  19. #19
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    brake oil has a prscribed life .. as u quoted so it must be 1 yr .. after that, it expires .. reduces in compression quality and reacts with rubber parts resulting in early failure of brake kits and reduced brake efficiency
  20. #20
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    a very detailed discussion here .. as such avoid towing with front wheels rolling
    https://www.pakwheels.com/forums/hon...-transmissions
