Results 1 to 9 of 9
Thread: Mileage drop issues with Nissan Mocco 2007, advice needed
    bakhtbaryar's Avatar
    Jun 2015
    23
    82
    Default Mileage drop issues with Nissan Mocco 2007, advice needed
    I took my mother's mocco for a routine check at about 80k kms. Had the following done:
    -Engine oil changed (Earlier was Havoline but it wasn't lasting even 2500 km so tried Kixx on a friend's recommendation)
    -New Filters
    -Spark Plugs Changed
    -Transmission Oil was changed
    -Coolant was replaced
    Now the mileage has dropped from 15 km/l (With A/C urban drive) to about 10 km/l (with A/C urban drive) and the car feels heavier too
    Any suggestions what could be wrong?
    KeiWorks12's Avatar
    Mar 2012
    1,298
    13
    94 Post(s)
    Which grade oil is poured in your car now? And which transmission oil?
    Sent from my SM-J700H using PW Forums mobile app
    KeiWorks12's Avatar
    Mar 2012
    1,298
    13
    94 Post(s)
    Also was the throttle body serviced aswell? I have heard most 660cc cars becomes heavier and gives less mileage when throttle body is serviced. Maybe because of incorrect procedure
    Jun 2015
    23
    82
    No Throttle body was not serviced. The Oil was 20/50.
    Could wrong kind of spark plugs be causing this?
    waleed96's Avatar
    May 2014
    20
    334
    5 Post(s)
    Was engine oil level decreasing?
    20w50 is a very thick oil for this engine and it isn't recommended.
    Use 5w30 or 5w40 viscosity oils for this engine.
    My advice is to drain your current oil and pour any of the above mentioned oil of either Zic or Shell.
    MBILALNAWAZ's Avatar
    Jun 2011
    Rawala kot
    1,223
    10 Post(s)
    Quote Originally Posted by bakhtbaryar View Post
    oil is too thick IMO and knowledge, these 660cc are designed to take 0w-20 or 5w-30( written in manual as well as inside the bonnet), I think i repeat i think max u can opt for is 10w-40. Hope it might help, rest wait and see the senior to come to help.
    Jun 2015
    23
    82
    Will change engine oil tomorrow and report back
    Jun 2015
    23
    82
    Everyone thanks for the help... the engine oil change solved the problem and the 20-50 Kixx had practically started clogging together chagned it with Byco 10-30
    IsbCap's Avatar
    Aug 2009
    1,865
    159 Post(s)
    3 Thread(s)
    10w-30 may be fine in current summer conditions, but still too thick for winters. I use 5W-20 in all weathers in my nissan sunny and never faced a problem. Excellent mileage figures even from 1500cc engine on a sedan.
