Results 1 to 5 of 5
Thread: Spark Plug Condition
    nabeegh10's Avatar
    Jun 2014
    33
    Default Spark Plug Condition
    This is 1 spark plug of 3 and this is the middle one, which has carbon and other 2 are all okay
    Can anybody tell me what is the problem with it? any suggestions?
    See the spark plug condition in attached pictures
    Car: Cuore
    Model: 2007
    Spark Plug made: NGKSpark Plug Condition -1702809Spark Plug Condition -1702810Spark Plug Condition -1702811Spark Plug Condition -1702812Spark Plug Condition -1702813
    saboor73's Avatar
    Oct 2013
    10,554
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    there could be three reason behind it
    1)2 cylinder is losing compression
    2)or spark is weak in second cylinder
    3)spark plug itself is bad
    nabeegh10's Avatar
    Jun 2014
    33
    Quote Originally Posted by saboor73 View Post
    3) spark it self is bad
    So what to do now?
    waqqas77's Avatar
    Dec 2013
    76
    2 Post(s)
    The residue on plug looks oily to me. U have a cylinder oiling up problem.
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,597
    31
    6
    1019 Post(s)
    19 Thread(s)
    5
    6
    check valve seals of this particular cylinder are dying @syncview - 1st check for engine compression, and replace valve seals of all 3 cylinder if 1 cylinder [ the bad spark plug ] differ on compression reading.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
Tags for this Thread
