Results 1 to 2 of 2
Thread: Cultus Brake Issue
    altafmushtaq's Avatar
    Jun 2016
    11
    Default Cultus Brake Issue
    Dear All,
    i have a problem in cultus Brakes, sometime my cultus 2005 brakes very well but sometime when i push slowly the brake paddle it completely pushed at the end and brake is not applied.
    Kindly advice what is the problem because mechanic is not understand the reason.
    Suzuki Motor said to change the following parts.
    Disk Pad, disk plate, Rear Break show, & rear wheel drum.
    Thanks
    tintin1's Avatar
    Jan 2014
    1,842
    8
    61 Post(s)
    2 Thread(s)
    7
    5
    Quote Originally Posted by altafmushtaq View Post
    Dear All,
    Thanks
    My guess, its master cylinder need to replaced or its brake oil is contaminated and should be replace.
    But before doing that, disks, hubs, pipes, etc. need to be properly checked and calibrated.
    Or as an experiment, replace the brake oil first. Drain the previous one and add the new one. Hope this problem will be solved by simply changing its brake oil.
    Be Addicted To Help Others.
