Results 1 to 7 of 7
Thread: brake oil
    trojan's Avatar
    Jul 2004
    29
    1,107
    Default brake oil
    hello ..
    I have noticed that brake oil of my car is decreasing not too much but a little bit ..Is there any problem ?
    n forever shall the wolf in me desire the sheep in you!
    memphis's Avatar
    Dec 2006
    33
    1,134
    I think if its a very minute amount then its ok, but if it disappears everytime you replenish it then it might be leaking.
    leolion007's Avatar
    Dec 2006
    34
    275
    which car do u have?
    trojan's Avatar
    Jul 2004
    29
    1,107
    well its not decreasing fully ..just i replenish and i find oil level a little below max I have coure 1995
    memphis's Avatar
    Dec 2006
    33
    1,134
    inspect the inner side of the wheel hubs, if its leaking crud would be accumulating there.
    leolion007's Avatar
    Dec 2006
    34
    275
    there is leackage check rear brake cylinders or seals and front brake disk cylinder, also master cylinder.and if these things are ok check the brake Survey.
    Site Banned Follow
    guy4u's Avatar
    Feb 2006
    86
    4,120
    update ?
