The garnish costs around 6000 from Bilal gunjh in lahore it is available in islamabad as well but i dont know the exact place for it the thing i have come across is now my car needs big brakes four disc brakes cause the braking is terriable it isout of control when you push the peddle i dont know how adnan would be feeling about it but it is not to front heavy any suggestions
@stonedsaint The engine cost is around 9500 rs from shuba peshawar with full ecm and wires if interested i would give you the complete address of the fellow who does the conversion , If you sell your old engine you will get the new engne fro around 5500 rs now isnt that cheap , As far as the consumption is concerned in city it is very good indeed much closer to the old engine , Your old transmission will work well with this all you have to do is put an extra 5th gear which would cost you around 4000 rs and you will have 5 speed , 5-speed would not be benificial to you if you have the same old lame 8valve 1.5 ohc engine cause it just not have enough grunt into it ,The interor is the costly bit full cielo interior would cost you around 30,000 with automatic doors and cielo dashboard again if swapped with the old one price would come down but you really have to search for good parts cause there is a lot of junk,Paint job again depends upon the place , locality and the individule who is painting the car the only thing i can tell you is that it is cheaper in peshawar then islamabad and lahore ,
As far as the AC in concerned it is fitted with its original compressor which does a job well the old daewoo compressor wont fit that good
The cars beaten so far are
(rather a list)
1.Corolla Se-Saloon 1.6 twincamvalve
2.Corolla GLI 1.6 twincam 16valve
3.Honda City 1.5 Prosmetic
4.Honda Civic 93, 95,2000 many times
As Adnan said it you will feel tht there is mush more grunt in the engine as previously stated
with regards to all
Amir
