Results 1 to 7 of 7
Thread: Santor Injactors Prob.
    daudbros's Avatar
    Aug 2004
    51
    543
    6 Post(s)
    Default Santor Injactors Prob.
    Hi,
    My santro doesn't run good on fuel (petrol) but it's run fine on CNG. Mincanic said it's due to block Injectors. It's there any fuel treatment. Which help to remove blockage. without opening Injactors.
    Thanks
    levin's Avatar
    Oct 2005
    Select City
    51
    23,112
    5
    95 Post(s)
    6 Thread(s)
    spraying carburator cleaner bottle may help, you have to pull out injectors to clean.
    dont loose the washer inbetween injectors fitting.
    another option is to buy good 2ndhand injectors from market to see if that is the exact problem if spray/clean donest help.
    ,,, unless you know the track, you're not good enough to sit behind the wheel." K T
    funkycapricorn's Avatar
    Jul 2005
    27
    1,157
    Santro has Electronic Injectors as far as I know So Use the Injector cleaner that has to be added with petrol!!! I will post the pic of the product I use later!!! I recently added it in my Chery!!!
    Labrador Puppies FOR SALE: http://www.pakwheels.com/forums/sale/139500-labrador-pups-show-winner-parents-sale
    daudbros's Avatar
    Aug 2004
    51
    543
    6 Post(s)
    thanks u guyes, I am waiting for ur next message.
    mon2006us's Avatar
    Jan 2006
    Bahawalnagar
    28
    447
    santro as a whole is a house of problems.
    i m one of those bad things which happen to good people.
    haroon131's Avatar
    Aug 2005
    31
    299
    dear first of all detached ur Intake manifold along with throttle body and injectors then spray 2 to 3 bottles od carb cleaner in it and after that run injector cleaner with petrol u will fell the difference
    u r running ur car on cng and there is some back compress due to cng thats why the oil goes to intake u have to spare Rs.2.5k to 3k for this maintenance
    TC
    daudbros's Avatar
    Aug 2004
    51
    543
    6 Post(s)
    Good information, from u guyes specialy Haroon131. I will try it and let u know.
