Results 1 to 12 of 12
Thread: Will someone please help!!!
    HumanGenius's Avatar
    Mar 2007
    22
    4,547
    Default Will someone please help!!!
    Subject : Toyota Owners--! Please help
    Salaam.
    I need to ask a few questions :
    1) Will adding an alarm kit w/ receiver/transmitter to an Altis which came standard with keyless entry be a problem?
    2) What did members with broken Toyota remote embedded keys do? ( keys of saloon & altis)
    3) Is there any place in ISB where I can get highest quality replacement key covers (the black part)
    4) If I install a new remote sensor and receiver to my Altis, will it reduce the security level of the car and by how much.
    5) Whats the best solution given the problems :
    - Broken remote key, remote still works tho.
    - Code of key/remote lost.
    - Company chargin 21k for new keys.
    My thought was get an alarm kit which will feature its own remote and then use the spare key of the car individually. Though, will this be a security issue given that the original receiver/transmitter will be subsided and new ones in use?
    All suggestions welcomed, thanks
    Syed
    What good is a Genius without the Human aspect?
    saadisb's Avatar
    Aug 2006
    28
    2,684
    3 Post(s)
    i have seen only keys available 4 sale. but as u said that the code is lost it may be a prob.
    How to Modify Your car: Put some fiberglass crappy looking bumpers, spoilers are essential for your daily driver, and don't forget the TypeR.
    ZXMCO's Avatar
    Dec 2004
    Faisalabad
    31
    398
    11 Post(s)
    In my opinion, you should go for original keys which is according to you is Rs.21k/- (In case of warranty/guarranty still exsist).
    My father also have 1.8XLi in Kuwait, the company said,if you have any problem, plz contact with us, otherwise warranty void in case of improper repair from outside the company.
    they provide three keys along with the car, all keys are with immboilizer
    Black
    : normal key,operates with all locks,ignition,trunk.
    Gray
    : same as normal but not operate only in trunk.
    Black w/Remote Control
    : Operates with all locks,ignition,trunk. w/LOCK n UNLOCK button.
    Prices
    Black w/Remote Control : 45/- K.D or 10000/- Rs (approx.)
    Black n
    Gray
    : near 20/- K.D (i think)
    (Y) Giddy Up!
    Mar 2007
    22
    4,547
    @ZXMCO
    20k is a bit too pricey dont you think!
    also keep in mind the code is lost, i dont think they can make another remote key..?
    @saadisb
    What do you mean by "only keys", metallic or with the black cover. Thats really what i need
    saadisb's Avatar
    Aug 2006
    28
    2,684
    3 Post(s)
    ^^^i meant the keys wid remote. incase u have the code than u can buy them and they will work on ur existing system.
    20k is too much high and sure a rip off as its not an immobilizer system.
    try other methods to locate the code.
    ZXMCO's Avatar
    Dec 2004
    Faisalabad
    31
    398
    11 Post(s)
    @HumanGenius
    1st, why did you purchase THAT corolla
    IN PUNJABI ( tu hi kya hona,"Abu g, corolla lainay aan." )
    2nd, they also have to find the code for the keys,thats the tough part. no problem for them. they just find the code, take out the keys n give it to you. no chik chik.
    or you have to find it ur self.
    IN PUNJABI( kadi ignition khool, kadi door lock khool, kadi diggi da lock khool. faair wichoon lub, blah blah )
    thats the only solution i got.
    cheerz
    (Y) Giddy Up!
    Mar 2007
    22
    4,547
    Have tried a LOT to find the code, but I think its been sweeped and thrown in the garbage now! Cuz it was on a small table and probably fell over and then cleaned by the maid so...
    How about installing an alarm system which will give me a new remote so i can use the spare key and remote as individual pieces. THough will this decrease the secuirty level of the car?; as the original "high-quality" receiver is being subsided and a new local one installed. Please advise on if this method will decrease the security of the car and then by how much.
    @ZXMCO
    I purchased the car cuz i already had a civic and this was the best option at that point. Mitsubishi Lancer didnt have ABS or even 4 discs, Nissan sunny was like 15Lak for 1.6 A/T. I got this for 13.1 Lakh. Plus it is our first Toyota ever and we plan never to buy one again...!
    ZXMCO's Avatar
    Dec 2004
    Faisalabad
    31
    398
    11 Post(s)
    agar ALTIS le hai to theek hai. agar XLi ya GLi lee hai to LANCER ko burra bhalla mat kaho. XLi, GLi say booht achi. kum say kum JAPANESE MADE to hai na.
    (Y) Giddy Up!
    Mar 2007
    22
    4,547
    Never mind why we got it, but now there is a serious issue, so plz help. Cmon, please read the topic questions and then answer.
    Regards
    Syed
    Mar 2007
    22
    4,547
    Mar 2007
    22
    4,547
  12. #12
    Mar 2007
    22
    4,547
    yar anyone !
